eg sway bar
Old Mar 1, 2005 | 01:51 AM
808State's Avatar
New User
Default eg sway bar
which rear sway bar do you recommend for my 92 civic si?
Old Mar 1, 2005 | 03:45 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: eg sway bar (808State)
A 14mm OEM GSR sway would do the trick. So would a 13mm LS one. If you choose ITR, you must get a beaks kit, but even then, you risk subframe damage. Stick with GSR.
Old Mar 1, 2005 | 06:47 AM
overrev130's Avatar
go with a stock gsr, its good enough. But if you want it stiffer, go with eibach.
Old Mar 1, 2005 | 07:00 AM
. o 69 o .'s Avatar
Default Re: eg sway bar (overrev130)
The ITR bar is nice on my EG.... i have front and rear. Well worth the upgrade
Old Mar 1, 2005 | 11:48 PM
808State's Avatar
New User
Default Re: eg sway bar (B16B)
do i need to change lca for itr or gsr rear sway bar? my 92 si hatch doesn't have a rear sway bar.
Old Mar 1, 2005 | 11:50 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808State &raquo;</TD></TR><TR><TD CLASS="quote">do i need to change lca for itr or gsr rear sway bar? my 92 si hatch doesn't have a rear sway bar.</TD></TR></TABLE>
I'm pretty sure your lca's are like the dx ones, so if they are you'll need to swap them out for Integra ones. Don't get itr lca's because the strut mounts differently to them.
Or, you could always drill your stock ones.
Old Mar 1, 2005 | 11:52 PM
JDMlyfestyle's Avatar
ive always wondered about the Eibach kit. does it come with New LCA's? cause i was reading at tire rack and didnt see anything mentioned about using a different LCA
Edit**** 6000post**** woot
Old Mar 1, 2005 | 11:56 PM
mikehawkBUiLT's Avatar
Default Re: (JDMlyfestyle)
i have suspension techniques. i like it.
Old Mar 2, 2005 | 03:42 AM
. o 69 o .'s Avatar
Default Re: (emo-ejcoupe1.6)
if you car does not have provisions for a rear sway bar, you could always get some LCA's like SSR or Omni Power. Doint go with ITR ones unless you are planning to run suspension like Tein, Tanabe , Ohlein
Old Mar 2, 2005 | 05:10 AM
Jon V's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">if you car does not have provisions for a rear sway bar, you could always get some LCA's like SSR or Omni Power. Doint go with ITR ones unless you are planning to run suspension like Tein, Tanabe , Ohlein</TD></TR></TABLE>
You guys keep saying this about the ITR LCA's. I thought it was just the JDM ITR LCA's that were different?
and what about the front LCA's on the 2-5 did they come with a front sway or do you need to switch those out too?
Oh yah... Why don't you do a search... there are like a million sway bar threads, go look at them...
Old Mar 2, 2005 | 06:13 AM
AGS's Avatar
AGS
JDM ITR Rear @ 22mm
Any Intergra Front Bar 22-24mm (i believe)
Cheap and easy to install.
Old Mar 2, 2005 | 06:14 AM
. o 69 o .'s Avatar
Default Re: (Jon V)
all ITR LCA's are the same. The JDM EG6 rear LCA's are also the same. For front LCA's, you can use any 94-01 integra ones. they all have front sway bar provisions. Also,if you are going to upgrade to integra ones, do yourself a favor and install new energy suspension polyurethane bushings. its cheap and well worth it
Old Mar 2, 2005 | 12:10 PM
litterbox's Avatar
Default Re: (B16B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B &raquo;</TD></TR><TR><TD CLASS="quote">all ITR LCA's are the same. The JDM EG6 rear LCA's are also the same. For front LCA's, you can use any 94-01 integra ones. they all have front sway bar provisions. Also,if you are going to upgrade to integra ones, do yourself a favor and install new energy suspension polyurethane bushings. its cheap and well worth it</TD></TR></TABLE>
ES bushings are well worth it. If you have the ability to press out the old bushing and press the new ones in, definitely get them. You can use a vice to do that. I have them on my car and they are excellent.
Old Mar 2, 2005 | 12:11 PM
POE's Avatar
POE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emo-ejcoupe1.6 &raquo;</TD></TR><TR><TD CLASS="quote">i have suspension techniques. i like it.</TD></TR></TABLE>
me too!
19mm
JMelt4
Suspension & Brakes
Jun 18, 2007 10:36 AM
null.
Aug 7, 2004 12:03 PM
litterbox
May 10, 2004 08:14 PM
KOME
18
Jun 14, 2003 03:22 PM
Jimmy L
Dec 29, 2001 04:22 PM
