SRS light after aftermarket steering wheel install.
Old Feb 28, 2005 | 11:59 PM
black cx's Avatar
Default SRS light after aftermarket steering wheel install.
For some reason my SRS light is on after installing my detachable steering wheel setup. I did this before in my other hatch and the SRS didnt come on. I did the install exactly the same. How can i turn it off?
Edit, also, in my old hatch, i had a JDM cluster...does that make a difference because right now i have a USDM cluster on my eg.
Old Mar 1, 2005 | 12:02 AM
BlueIntegraBoy's Avatar
Default Re: SRS light after aftermarket steering wheel install. (black cx)
Pull the bulb. Of course it would come on since you don't have airbags.
Old Mar 1, 2005 | 12:07 AM
SirRevvs's Avatar
Default Re: SRS light after aftermarket steering wheel install. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Pull the bulb. Of course it would come on since you don't have airbags.</TD></TR></TABLE>
Pull the bulb and the fuse.
Old Mar 1, 2005 | 02:03 AM
junek00's Avatar
Default Re: SRS light after aftermarket steering wheel install. (C_DUB)
ya
Old Mar 1, 2005 | 05:19 AM
EK45VTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C_DUB &raquo;</TD></TR><TR><TD CLASS="quote">Pull the bulb and the fuse.</TD></TR></TABLE>
What if he pulls out JUST THE FUSE??? Would the SRS light still appear?
Must he pull out both the bulb and the fuse or would the fuse be suficient?
Old Mar 1, 2005 | 05:24 AM
smithenhiven's Avatar
11:11
Default Re: SRS light after aftermarket steering wheel install. (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">What if he pulls out JUST THE FUSE??? Would the SRS light still appear?
Must he pull out both the bulb and the fuse or would the fuse be suficient?</TD></TR></TABLE>
Good question. I was wondering the same thing since I have an SRS light in my 98 Civic. Where is the SRS fuse anyway?
Old Mar 1, 2005 | 07:10 AM
SweetSol's Avatar
Default Re: SRS light after aftermarket steering wheel install. (smithenhiven)
Forget about the fuse. Just pull the bulb. That's what I did. If you have a passenger side airbag and pull the fuse, the airbag will not work.
Old Mar 1, 2005 | 07:44 AM
Evil-EK's Avatar
Default Re: SRS light after aftermarket steering wheel install. (SweetSol)
Just unplug the YELLOW plug going to the srs bulb on the back of the cluster.
Old Mar 1, 2005 | 08:48 AM
overrev130's Avatar
JUST PULL THE YELLOW PLUG, ITS EASIER.
Old Mar 1, 2005 | 06:11 PM
black cx's Avatar
Default Re: SRS light after aftermarket steering wheel install. (overrev130)
thanks
92ehatch
19
May 8, 2007 08:57 PM
bb4ninja
Feb 21, 2007 08:25 AM
ososlow24
11
Nov 4, 2004 05:16 AM
vtec69
Jul 21, 2004 12:59 PM
R-gonaut
Nov 7, 2002 07:47 PM
