Ecu chipping!!!
Old Feb 28, 2005 | 09:32 PM
UnforgottenPresence's Avatar
Default Ecu chipping!!!
When you chip an ecu r u adding a component or replacing it with one? How do you program the chip before you install it? I am interested i ngetting into ecu chipping can anyone give me an example or tell me where to seearch on how to do it?
Old Feb 28, 2005 | 11:43 PM
TurboLSVtecTeg's Avatar
Default Re: Ecu chipping!!! (UnforgottenPresence)
When you chip an ECU you much desoder the board(thru holes). Then add components. Depending on what ECU your doing its a 28pin DIP Socket, ZIF Low Profile 28pin DIP Socket, Atmel AT29C256 EEPROM, 2 capacitors, 1 resistor and a jumper wire.
You will need some type of program that will create a file that you can burn to your chip. Then you will need a burner compatible with the chips your running.
Here is a site for starters.
http://home.mn.rr.com/keebler65/honda/index.html
Old Mar 1, 2005 | 06:16 AM
Default Re: Ecu chipping!!! (TurboLSVtecTeg)
Is there other programs besides uberdata that can be burned to the chips??
Old Mar 1, 2005 | 06:51 AM
mmuller's Avatar
Mad Scientist
sure you have a bunch; my favorite is crome.
read up here; this site is a gold mine.
pgmfi.org
Old Mar 1, 2005 | 07:24 AM
thatbluecrx's Avatar
look for HT member civic 4 ges, he seems to know everything about chipping!
Old Mar 1, 2005 | 03:35 PM
Default Re: Ecu chipping!!! (thatbluecrx)
is there a way to edit the rom without removign it fro mthe ecu like if u wanted to plug in a laptop and run it with the car on? Like a hookup u can add while chippign the ecu?
Modified by UnforgottenPresence at 6:50 PM 3/1/2005
Old Mar 1, 2005 | 06:22 PM
ttt
Old Mar 1, 2005 | 09:30 PM
Jim Truett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnforgottenPresence &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to edit the rom without removign it fro mthe ecu like if u wanted to plug in a laptop and run it with the car on? Like a hookup u can add while chippign the ecu?
Modified by UnforgottenPresence at 6:50 PM 3/1/2005</TD></TR></TABLE>
Romulator, ostrich, pgmfi.org RTP.
Like mmuller said, http://www.pgmfi.org is what you need.
david76008
Engine Management and Tuning
32
Apr 1, 2009 07:07 AM
95sloweg
Jan 14, 2008 05:46 PM
matto2413
Nov 8, 2004 10:06 PM
Doubledeala
Oct 15, 2004 05:00 AM
