Tech 43 kit questions?
Old Feb 28, 2005 | 09:02 PM
JDMlyfestyle's Avatar
Default Tech 43 kit questions?
Ok here are some ?'s that i have been wondering about
I use the Main caps in the B16 correct?
what bearings would i use? and what should the clearance be on the crank? do i use the green plastiguage?
I want to run a girdle with this system. can i use the stock B16 windage tray, pan and pick up? if not what do i need?
If i run the girdle what Stud kit would i use? the GSR or B16?
Also if i was running the 82 mm kit with the block guard. would 9k be safe to hit. I did over 80 passes last season plus a few show ups at a light
thanks thats all the questions i have.
Modified by JDMlyfestyle at 3:47 AM 3/1/2005
Old Feb 28, 2005 | 09:18 PM
Kendall's Avatar
Default Re: Tech 43 kit questions? (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">I use the Main caps in the B16 correct?</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">what bearings would i use? and what should the clearance be on the crank? do i use the green plastiguage?</TD></TR></TABLE>
You use OEM GSR bearings and clearance them as such.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">I want to run a girdle with this system. can i use the stock B16 windage tray, pan and pick up? if not what do i need?
If i run the girdle what Stud kit would i use? the GSR or B16?</TD></TR></TABLE>
These I don't know, but Steve is usually on and off often enough to handle most questions. Shoot him a PM or give him a call.
Old Feb 28, 2005 | 09:51 PM
WrongWD's Avatar
you will need a gsr windage tray, pan and pick up, though i am unsure on the studs
oh, and ITR stuff works too.
Old Feb 28, 2005 | 09:58 PM
i shot him a PM a couple days ago still no response.
Old Feb 28, 2005 | 10:02 PM
onepoint6i's Avatar
Default Re: (JDMlyfestyle)
its gonna be faster to send him an e-mail
Old Feb 28, 2005 | 10:25 PM
rodimus's Avatar
Default Re: (1.6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.6i &raquo;</TD></TR><TR><TD CLASS="quote">its gonna be faster to send him an e-mail</TD></TR></TABLE>
Old Feb 28, 2005 | 11:53 PM
TECH43 RACING INC.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">Ok here are some ?'s that i have been wondering about
yes. you always use the original main caps on any engine, regardless of stroke.
You have two choices.
1. oem (the only ones I use)
2. a aftermarket "standard" bearing set, ie: clevite, acl, king etc.
btw, all b series bearings are the same, with the exception of b18c rod bearings which can be easily fit into non b18c rods.
I only use oem bearings because I truly "blueprint" my engines and I adjust my bearings to achieve the vertical oil clearance I want. Alot of people use standard "one size" bearings, and for the most part, have no problems, but remember, they are pretty much stuck with one clearance unless you have access to crank journal grinding.
I don't use plastiguage, I use dial bore guages and micrometers. Plastiguage is designed for basic "rebuilding". in my opinion, its only good for making sure your clearances aren't too tight, and even at that, its a weak "eyeballed" estimate.
basically, I'm really **** and like to put my parts exactly where I want them, and I try to go for every last bit of power and reliability.
I want to run a girdle with this system. can i use the stock B16 windage tray, pan and pick up? if not what do i need?</TD></TR></TABLE>
any time you put a "girdle" on a non girdled b series engine, you will be required to use b18c windage tray, the 6 girdle bolts, oil pickup, and oil pan.
but for the record, I don't believe that non girdled b motors need girdles. if you're running hot rod boosting 50 lbs making 1000 hp, I guess it can't hurt to use one, beyond that, save your money. if anyone disagree's....i'd like to see some failures due to a lack of a girdle. like my boy chuck d said: "don't believe the hype!"
the (6) fastners for the girdle need to be b18c length. stock, used bolts are fine. studs are not needed. the outer main caps use the original fastners.
Yes. I don't believe a sleeve cracking would be an issue, I would be more concerned with a rod failure at that rpm, although have lots of engines with 89mm cranks running 9k + with no problems, daily driver. I would reccomend forged rods for the added strength at that rpm.
I'm not a fan of block guards. I don't believe they add much strength. And most cylinders crack under detonation or rod/piston failure, not rpm.
I mean, how much rigidity can they add if you install them by lightly tapping them in?
WORD!
quickly goes into b-boy stance.
Modified by TECH43 RACING INC. at 1:08 AM 3/1/2005
Old Mar 1, 2005 | 12:14 AM
Thanks for answering my questions steve.. I am going to be using a forged rod. i believe i am settled on the Eagle I beam rods with ARP bolts.
Old Mar 1, 2005 | 02:22 PM
onepoint6i's Avatar
lol...I havent read a post like that from steve since that kid callmejesus was trying to doubt the b16 stroker kit!!
Old Mar 1, 2005 | 02:25 PM
ohh ya thats a instant classic. why am i listening to steve's dumbass? he doesnt know ****..
callmejesus can u show me the light?
Old Mar 14, 2005 | 07:01 PM
kaptr1d's Avatar
nope he cant, hes banned. =\
allmtrdc4
15
Mar 9, 2006 12:46 PM
fastrunner
Nov 29, 2005 11:20 PM
ek_slut
Aug 24, 2005 07:05 AM
ognuts
Mar 9, 2004 06:42 PM
DubyaAye
Jan 11, 2004 10:57 PM
