What kind of CamShafts do you recommend for a 99 GSR Turbo
Old Feb 28, 2005 | 05:37 PM
BtMplayboi's Avatar
Default What kind of CamShafts do you recommend for a 99 GSR Turbo
I got a 99 GSR Turbo, (all the upgrades can be seen in my signature) im building on the motor, what camshafts do you recommend for my engine....thanks
Old Feb 28, 2005 | 05:43 PM
Kendall's Avatar
It would really be helpful if you included such details as the compression ratio of the motor, but stock GSR cams usually do a pretty good job. Being that you aren't running a sleeved block, you won't be able to safely run insane amounts of boost and the stock GSR cams should be good.
93civiceg6's Avatar
leave your stock gsr cam they are the best for turbo on vtec engine because they have the least amount of overlap. my buddy has a 10 sec crx with a complete build up dart block 2.0 specs rods valves pistons everything and he is running on stock gsr cams
Old Feb 28, 2005 | 06:19 PM
5litereater's Avatar
Default Re: (93civiceg6)
if youre looking for something aftermarket, check out crower.
http://crower.com/cat/import/h...shtml
Old Feb 28, 2005 | 06:27 PM
tegsallgood's Avatar
Default Re: (Kendall)
i belive skunk has cams made for boosted applications. i think i remember reading that they are as ideal as gsr cams in terms of overlap but they also make power higher then gsr cams for built 10k revvers
Old Feb 28, 2005 | 06:36 PM
IggyBcool's Avatar
i'd just leave in the GSR cams, if im not mistaking Crower's uhhhh 404-T(correct?) are for turbo app's. and i hear there badass
Old Feb 28, 2005 | 08:44 PM
BtMplayboi's Avatar
Default Re: (99LStegra)
my compression in my engine is at 9:1
Snailor Built
Nov 16, 2013 10:07 AM
ukdmtony
Aug 7, 2011 10:49 AM
bmx-ej1
Jan 23, 2010 06:27 AM
tdark1582
Jan 11, 2006 01:44 PM
98B18C1
Oct 10, 2005 08:27 AM
