Cam in a D16z6???
I was looking into getting a cam for my Del Sol Si, just curious what cams you all are using w/ the stock valve train, and how much power you made, times run and all that. All input is appreciated
Also, how hight can the stock springs/retainers hold up to??? Thanks
-jase
Also, how hight can the stock springs/retainers hold up to??? Thanks-jase
I recommend Crower 2 if you don't want to upgrade valvetrain. I ran this cam w/ a completely stock head, and it made a ton of topend power. If you want more, then go with Crower 3, but you'll have to upgrade your valvetrain. Zex 59300 cam is a GOOD midrange cam 3500-6000, and I've ran it with stock head. Anyhow, you want good topend power go with Crower 2. You want midrange, go with Zex 59300. For ***** out power from 5500-8000, go with Crower 3.
don't over cam your motor. u have a stock bottom end? i'd recomend checking out exospeed.com that ake a great cam..... and if u want to spend a decent aount on your cam check out cat cams.... not to many people in america have herd or seen them but they make awesome power
USDM 4G VTEC
Mar 14, 2003 05:33 AM
