HELP!!!!! SOHC VTEC MINI-ME SWAP?
FIRST OF I OWN A 91 CIVIC SEDAN. IT HAS A D15B1 SOHC. AND I JUST PURCHASHED A D16Y8 SOHC VTEC HEAD AND WAS WANTING TO KNOW IF THE TWO WILL MATE, AND IS THERE ANY OTHER PARTS, WIRING OTHER THEN THE ECU THAT I WILL NEED TO COMPLETE THE SWAP? ANY INFO WOULD BE APPREICATED.
Yes the Y8 head will bolt directly to the D15B1 block. One of my current cars that I have is a 91 Civic Si with D15B2 block and Y8 head that I built. It's a decently mild setup, quite surprising for a D series motor. Since your car is DPFI, you would "want" to convert to MPFI using 88-91 Civic/CRX Si parts. This is the easy route to take and then use an RPM switch or VTEC controller (better option) to actuate the VTEC solenoid. You can also have a custom programmed PR3/PW0 ECU which would be best when staying OBD0. Another option would be to convert to OBD1 and use a P28 ECU but make sure you know what you are getting into before tackling that.
el_ache_veintidos
Sep 6, 2004 04:56 PM
