D series mini-me Question
If i have a D16y7, and i put the sohc vtec head on it.... i would also need to use the y8 ecu? and harness?
or how would i need to swap everything?
The Grumpiest
Re: D series Question
I love these. Doing a head swap with no parts list or directions? Check the FAQs. There are links for mini-me swaps.
VTEC controllers are fail. Especially when wiring VTEC is so easy.
Re: D series mini-me Question
thank you. I just bought my first civc... and have been looking around here... but thank you for the help.
So if i did that i'd basically have the sohc vtec right....
The Grumpiest
I guess you don't know where the FAQs are.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-d16y7-y8-mini-me-write-up-pics-56k-maybe-not-735196/
http://www.jdmuniverse.com/forums/view_minime.html
The Grumpiest
Well everything you need to know is in those 2 links. With pictures too.
This is the parts list. Pay particular attention to the item in BOLD.
-D16y8 Head
-D16y8 Intake Manifold
-D16y8 Throttle Body
-D16y8 Fuel Rail
-D16y8 Fuel Injectors
-P28 ECU ( May also use P2P ECU, I'll get into that later )
-An Intake Device. ( The new setup will put the Throttle Body on it's side, not up in the air. )
-Torque Wrench
-Head Gasket
-Copper Spray
-Intake manifold Gasket
-Throttle Body Gasket
-Exhaust Manifold Gasket
-Timing Belt
-Oil + Filter
-Coolant
-96-00 Honda Civic EX Spark Plugs
-Some Wire, and Wire Connectors
-Colored 3M Tape to mark Fuel Line, Vacume Lines, and Coolant Lines
-A box of Zip Lock Bags and a Sharpie. That way you know what bolts go where.
-D16y8 Head
-D16y8 Fuel Rail
-Torque Wrench
-Head Gasket
-Copper Spray
-Timing Belt
-Oil + Filter
-Coolant
straightshot08
10-29-2009 06:36 AM
