CRX . . LS/Vtec Setup
Old Feb 28, 2005 | 12:31 PM
mattj's Avatar
Default CRX . . LS/Vtec Setup
i need your imput. . . just turned honda, and i am not familiar with a lot of things . . help me out. opinions welcome . . .
Old Feb 28, 2005 | 12:47 PM
91 HONDAsaurus rex's Avatar
Default Re: CRX . . LS/Vtec Setup (mattj)
Before the flaming begins just use search key up top, you can get a lot of info on LS/VTEC and basically whatever you need to know. LS/VTEC is a b series motor with a B18 bottom end, usually b18a or b18b and a b series VTEC head like a B16 or B18C.
Old Feb 28, 2005 | 12:53 PM
mattj's Avatar
I already have the shell . . . and i was going to do the b18 block with the b16 head . . i was gettin told that i should just buy the b16 swap and then just find a ls block. that way i have the b16 tranny . .
i am just wonderin the pros and cons of ls vtec and what it can do
Old Feb 28, 2005 | 01:01 PM
Default Re: (mattj)
I cant exactly tell you the pros and cons, I have heard a lot of good and bad things about that combo. I have a slightly built B16A in my CRX and is good enough for me as a daily driver, I dont think its overrated like some people say on this site. If I were you I would buy one of the engines first and swap it in, preferably B16A since you just turned honda. Also you can learn a lot from your first swap. Then if you want to learn more or get more torque try and find an LS block or something. Search for LS/VTEC, I did like 2 weeks ago and found like 900 results.
Old Feb 28, 2005 | 01:14 PM
mattj's Avatar
i was also tyring to find different dyno sheets and **** for ls turbo . . . .
ls turbo vs . ls/vtec turbo
Old Feb 28, 2005 | 01:37 PM
Malgerus's Avatar
Default Re: (mattj)
Matt,
check out http://www.importreview.com
and
http://www.c-speedracing.com
Old Feb 28, 2005 | 01:42 PM
crxnj's Avatar
Default Re: (Mr. S)
If you build the lsvtec atleast get arp rod bolts,and have the bottem end balanced..And if you go turbo get some arp head studs so the mothafu**** head dont lift..
And to make it easy for you get the ge lsvtec kit..Allows you to put the dohc vtec head on a b18a/b without any machine work..
Old Feb 28, 2005 | 01:53 PM
Slow ass EF's Avatar
LS VTEC can get expensive, because if ur going to do it u have to do it right. its probably easier to buy a b16 swap and do that then build an LS VTEC
Old Feb 28, 2005 | 02:05 PM
ef8 h0!'s Avatar
Default Re: CRX . . LS/Vtec Setup (LSVTECJay)
well i have a head that would work great! pm me.
edit: b16a1 pr3 obd0 set up. come with mainfolds and dizzy. then youd just need the block and ecu.
Old Feb 28, 2005 | 02:11 PM
crxnj's Avatar
Default Re: CRX . . LS/Vtec Setup (ef8 h0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef8 h0! &raquo;</TD></TR><TR><TD CLASS="quote">
edit: b16a1 pr3 obd0 set up. come with mainfolds and dizzy. then youd just need the block and ecu.</TD></TR></TABLE>
B16a..No b16a1 unless its from europe..
Im picky..
Old Feb 28, 2005 | 02:12 PM
JDM Like Whoa's Avatar
Bump for nebraska bretheren.
Old Feb 28, 2005 | 04:39 PM
ef8 h0!'s Avatar
Default Re: CRX . . LS/Vtec Setup (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">
Im picky..</TD></TR></TABLE>
tuche
Old Feb 28, 2005 | 05:48 PM
doublethink's Avatar
something to consider is the LS block wont magically redline at what the b16a head is capable of.
sure it may do it for a while, but how long?
if you want high revs might want to look into a b18c swap.
if you really want an ls/vtec setup, youll need to get the block machined, or buy a kit, but that only makes the two pieces compatible with one another, that doesnt do anything for the weak bottom end, so youll be buying parts and doing work to beef that up, if you seriously look at price of all that, youll start to realize the gsr is a much better deal then people realize.
the swap really isnt any more work then any other b-series and has lots of potential.
it depends on how much work you want to do. lots of people do it all the time.
llansy
Oct 29, 2007 11:29 AM
89efsleeper
Nov 2, 2005 03:59 PM
davidcrx89
Jun 23, 2005 01:07 AM
Mr si99
10
May 7, 2005 10:41 PM
dc2_and_ef
Jan 3, 2004 05:58 AM
