VSS
Old Feb 28, 2005 | 11:33 AM
hondaracing1's Avatar
Default VSS
anyone got a diagram or picture showing where the vehicle speed sensor is?....thanks
Old Feb 28, 2005 | 11:50 AM
Ls_V_TurboSi's Avatar
Default Re: VSS (hondaracing1)
its on top of the tranny right by the rear tranny mount....
Old Feb 28, 2005 | 12:41 PM
WreckedTeggie's Avatar
Default Re: VSS (Ls_V_TurboSi)
The pic is a bit fuzzy for me to remember but this was about where it was on the b18c1 i had if i didnt circle the right one.. it is two 8 mm bolts, u need to take off the intake to get to it
Old Feb 28, 2005 | 04:00 PM
0bd1_Kanobe's Avatar
behind tranny mount, you should be able to see it its the long piece sticking out the tranny
Old Feb 28, 2005 | 05:59 PM
EG1.8cT68's Avatar
It is two tens for the speedo assembly located usually under you lower radiator hose at the head, behind the starter.
shortstopNE
Dec 28, 2008 08:01 PM
truplayaz24
Welding / Fabrication
14
Oct 17, 2007 10:02 AM
cincispeedemon
Oct 10, 2004 02:50 PM
cr-x si
16
Jun 19, 2003 09:13 PM
oatsuzn
Sep 2, 2002 03:04 PM
