ITR on a Civic 98
ITR in A Civic NO POWER???
Hi guys!! i'm new here and have a couple question on my ITR swapped civic, any help will be appreciated. This is what I have in the swap:
ITR Block
Brand New ITR Head,
Brand New ITR CamShaft,
B16 Tranny,
ARP HeadStud,
OEM Head Gasket
APEX'I VAFC
JG Intake Manifold, 68mm STR Throttle Body,
Brand New Over-Sized CTR Piston & Ring,
Brand New Main & Rod Bearing,
the car ran about 300 miles on 93 Octane Gas, no noise, Vtec working, ( but can't feel any power), when the engine is cold it cannot idle ( the car dies after letting go Gas pedal). compression of the car is 270 all 4. It feels like an 99 Civic SI.
Any body know why the car is not producing any power??? Plz help thx!!!
Modified by civictuner1105 at 6:09 PM 2/27/2005
Modified by civictuner1105 at 6:18 PM 2/27/2005
Modified by civictuner1105 at 6:39 PM 2/27/2005
Modified by civictuner1105 at 6:45 PM 2/27/2005
ITR Block
Brand New ITR Head,
B16 Tranny,
ARP HeadStud,
OEM Head Gasket
APEX'I VAFC
Re: ITR in A Civic NO POWER??? (BlueIntegraBoy)
I think i'm running a GSR ECU, also i have the apex'i VAFC install that i forgot to mention, does that make a difference??
Re: ITR in A Civic NO POWER??? (civictuner1105)
If you can find a 97-98 P73, or convert to OBD1 and get a P28. Then get it tuned. Right now your VTEC is kicking in at 4,400 instead of 5,500, and the ECU is looking for the IABs, which you don't have. I don't think you'll have good low end with that P72.
I dont' think IABs is the problem. or would be much of the different in term of power. I have done a swap before without connect the IABS and that gsr make good power, after that I connect the IABs and didn't feel any different.
Location: americas finest, calee fourn ya, united states
Try checking your fuel system make sure your fuel filter is not clogged,that can stop the injectors from getting enough fuel. you said the distributor is good so that shouldn't be the problem. check for leaks fuel injection, intake manifold and all vacuum hoses make sure exhaust not clogged. sometimes the littles things we forget can set us back. also check valve clearances. good luck.
I think you need to run the correct ECU...
Doesn't the GSR have dual runners? blah blah blah
get a new ECU and come back with some results...
If I were you I would splurge and get something tunable
civictuner1105
13
05-22-2005 09:40 AM
civictuner1105
13
02-28-2005 05:31 PM
