LSD?? how do i know? if i have it ?
it's a 94 gsr. i know that they dont come with LSD unless it's jdm, right ? when ever i do a burnout or anything that causes my wheels to spin.. both wheels turn? does that mean my trans has LSD or no ?it's something else
Put the car in the air (jackstands, lift, whatever) and spin one of the tires with your hands. If the other wheel spins the same direction, it's equipped with a limited slip. If the other wheel spins the opposite direction, it's not equipped with a limited slip, or it's worn out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Put the car in the air (jackstands, lift, whatever) and spin one of the tires with your hands. If the other wheel spins the same direction, it's equipped with a limited slip. If the other wheel spins the opposite direction, it's not equipped with a limited slip, or it's worn out.</TD></TR></TABLE>
or when you take out your axles, you can see straight through the other side
NashDishesDimes
18
Oct 20, 2010 08:15 PM
ls95hatch
25
Oct 3, 2003 10:48 PM
