ITR in A Civic NO POWER???
Old Feb 28, 2005 | 11:17 AM
civictuner1105's Avatar
Default ITR in A Civic NO POWER???
Hi guys!! i'm new here and have a couple question on my ITR swapped civic, any help will be appreciated. This is what I have in the swap:
ITR Block
Brand New ITR Head,
Brand New ITR CamShaft,
B16 Tranny,
ARP HeadStud,
OEM Head Gasket
APEX'I VAFC
JG Intake Manifold, 68mm STR Throttle Body,
Brand New Over-Sized CTR Piston & Ring,
Brand New Main & Rod Bearing,
the car ran about 300 miles on 93 Octane Gas, no noise, Vtec working, ( but can't feel any power), when the engine is cold it cannot idle ( the car dies after letting go Gas pedal). compression of the car is 270 all 4. It feels like an 99 Civic SI.
Any body know why the car is not producing any power??? Plz help thx!!!
Old Feb 28, 2005 | 11:40 AM
cnyej1's Avatar
Default Re: ITR in A Civic NO POWER??? (civictuner1105)
Whats your VAFC set at etc? That could cause some shitty performance if it isnt setup correctly
Old Feb 28, 2005 | 11:43 AM
dantastic's Avatar
sounds like a timing issue. do you have cam gears on there? make sure they didn't slip. also check to make sure all the TDC marks are lined up
Old Feb 28, 2005 | 11:47 AM
cnyej1's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a timing issue. do you have cam gears on there? make sure they didn't slip. also check to make sure all the TDC marks are lined up</TD></TR></TABLE>
Oh yeah, I didnt even think of the timing, why? I dont know hehe long day.
Old Feb 28, 2005 | 02:15 PM
Default Re: (cnyej1)
the timing was perfect so i don't think is the timing, wat else can it be??
Old Feb 28, 2005 | 02:18 PM
igyloo's Avatar
what computer are you running?
Old Feb 28, 2005 | 02:21 PM
Default Re: ITR in A Civic NO POWER??? (igyloo)
gsr
Old Feb 28, 2005 | 02:37 PM
Ecko93civic's Avatar
play with your vfac some go extreme on it seeif that works did u double check your vfac wiring sure wiring is correct
Old Feb 28, 2005 | 03:41 PM
jeffk182's Avatar
Try running a ITR ECU
Old Feb 28, 2005 | 03:51 PM
JDMisGOOD's Avatar
Default Re: (jeffk182)
what year civic?
Old Feb 28, 2005 | 03:56 PM
Irishweird00's Avatar
Banned
Default Re: (JDMisGOOD)
Take that piece of **** VAFC out of your car.... and your problems will sort themselves out.
ninety5itr's Avatar
just disconnect the vafc and run a chipped p28
Old Feb 28, 2005 | 03:57 PM
ReDHaTcHyGuy's Avatar
Default Re: ITR in A Civic NO POWER??? (Ecko93civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ecko93civic &raquo;</TD></TR><TR><TD CLASS="quote">play with your vfac some go extreme on it seeif that works did u double check your vfac wiring sure wiring is correct</TD></TR></TABLE>
if u don't know what ur doing don't play with the setting on it u will blow ur motor.. i'd get the timing checked .. that JG mani is killing u alot.. there made for high comp or turbo setups 7-10k rpms,, u would be way better off with a type-r or skunk 2
Old Feb 28, 2005 | 05:31 PM
Default Re: ITR in A Civic NO POWER??? (ReDHaTcHy97)
timing is not the problem. even the jg manifold is too big for it, but can't kill the power that much. there have to be some other problem. i will try to remove the vafc later.
civictuner1105
13
May 22, 2005 09:40 AM
JDMjdawg
Mar 20, 2005 05:34 PM
civictuner1105
13
Feb 28, 2005 06:00 PM
9krpm
Jun 22, 2004 10:23 AM
