Wet Nitrous Kit Fuel line
Old Feb 28, 2005 | 07:19 AM
mongoliandonuts's Avatar
Default Wet Nitrous Kit Fuel line
Does the wet nitrous fuel line connect into the in on the fuel filter? i've never done this before some Im somewhat confused. If so how does it and if now where does it hook in?
Old Feb 28, 2005 | 07:41 AM
modedicebox's Avatar
Default Re: Wet Nitrous Kit Fuel line (mongoliandonuts)
I hope this is for a nitrous express fogger kit type of application:
you should have a "T" fitting in the kit,if not go get one.Then you need to cut the fuel line that comes off you fuel rail and travels down to a hard line on the right side(looking at the motor).Make sure your fuel line is in good shape i had to replace mine. Then install "T" fitting using hose clamps then tighting everthing up.
make sure nothing leaks.good luck
Old Feb 28, 2005 | 09:07 PM
Default Re: Wet Nitrous Kit Fuel line (modedicebox)
the line that runs off the FUEL pressure regulator? not the Fuel line that runs from the Fuel filter to the Fuel rail?
Old Feb 28, 2005 | 09:14 PM
eK9aT10pSi's Avatar
what car/motor ?
Old Feb 28, 2005 | 09:19 PM
vtec y0's Avatar
Default Re: Wet Nitrous Kit Fuel line (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modedicebox &raquo;</TD></TR><TR><TD CLASS="quote">I hope this is for a nitrous express fogger kit type of application:
make sure nothing leaks.good luck </TD></TR></TABLE>
Old Feb 28, 2005 | 09:50 PM
Default Re: Wet Nitrous Kit Fuel line (vtec y0)
del sol si. with a jdm b16a swap
dominidg123
Jun 2, 2009 05:42 PM
dohdoh420
Sep 8, 2006 12:20 PM
honda3x23
May 12, 2006 09:08 PM
AaronJ
May 20, 2005 12:23 PM
dseriessol
Aug 17, 2003 04:25 PM
