Thinking about getting a Chikara exhaust ...
Old Feb 28, 2005 | 01:44 AM
Synthead's Avatar
Default Thinking about getting a Chikara exhaust ...
http://store.summitracing.com/...earch
What do you think? I have a 1988 Honda Prelude 2.0Si that would love to have one of those. My stock one is all banged up on the underside restricting a bit of airflow and making it run a little warm since the last time I drove it. Are they good manifolds?
What kind of tools would be required to replace my manifold? I bet those bolts are really stuck to the engine. The heads wouldn't snap off them if I really pushed them would they? Maybe putting a bolt loosener on first would help?
I was also told that the entire procedure could be done without taking the engine out of the car. Is this for real? Would I have to weld the manifold onto the enhaust system at all? Anything I should know for replacing the manifold?
Thanks for reading! I hope you can help in some way. This is the first time I'd be doing this procedure if I end up doing it.
Old Feb 28, 2005 | 02:25 AM
chandler's Avatar
you shouldnt have to pull the engine out of the car to replace a manifold, id put some penetrant on the bolts and let it soak in for a while before I went to crack them loose though
Old Feb 28, 2005 | 05:31 AM
clemsoncb7's Avatar
Default Re: Thinking about getting a Chikara exhaust ... (Synthead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synthead &raquo;</TD></TR><TR><TD CLASS="quote">http://store.summitracing.com/...earch
Thanks for reading! I hope you can help in some way. This is the first time I'd be doing this procedure if I end up doing it.</TD></TR></TABLE>
WTF? You would never have to pull the motor just to get the exhaust mani off. If its a direct fit, then you won't have to weld.
Old Mar 1, 2005 | 02:22 AM
Synthead's Avatar
Sorry if my questions were annoyingly newbish ... heh ... I'm still learning ...
Looks like I might have an investment set on me then! Are there any other headers that you would reccomend? I know DC Sports makes one, but they're not in production anymore so they're hard to get a hold of.
Old Mar 1, 2005 | 09:24 AM
elmo244's Avatar
i ordered one for my accord one time and i sent back to summit the next the next day.
Old Mar 1, 2005 | 09:29 AM
92LudeSI's Avatar
I got one for real cheap when I bought my exhaust. Mine is for an h23 but I honestly cant say that it did much for the butt dyno. The runners seemed the same if not smaller than stock and it will be all rusty and **** within a few months. I would not recommend getting one. But then again thats your decision.
Old Mar 1, 2005 | 02:17 PM
97Preludeguy's Avatar
Default Re: (92LudeSI)
You might wanna check out ebay, they make some nice DC replicas on there, which are probably higher quality and cheaper then the Chikara header that your lookin at. Just a suggestion...
thirdstartz
10
Apr 24, 2012 01:44 AM
ctag
10
Feb 22, 2012 07:16 PM
Battle2.0Eg
Honda Civic (2001 - 2005)
Sep 30, 2010 11:39 PM
jb0705
Jul 6, 2009 07:53 AM
nik_gujarathi
Dec 12, 2005 05:09 PM
