wut would i need to change my cable clutch to hydrolic clutch?
Old Feb 27, 2005 | 09:27 PM
xlusiveracer's Avatar
Default wut would i need to change my cable clutch to hydrolic clutch?
wut would i need to change my cable clutch to hydrolic clutch? how much money would i need to spend to change it?
Old Feb 27, 2005 | 09:33 PM
Beyond Imagination's Avatar
Default Re: wut would i need to change my cable clutch to hydrolic clutch? (xlusiveracer)
a hydraulic tranny and a cable to hydraulic conversion kit
Old Feb 27, 2005 | 10:17 PM
jdmcivicturbo's Avatar
u would need alot actually....not to hard but a long process....
hydralic tranny
hydralic lines from the master cylinder to the slave cylinder
hydralic lines from the brake pedal to the master cylinder...
i believe that should be it.....double check though
the tranny will run u any where from 250 on the streets to 500 really depending on how good of a tranny it still is in...and lines u could pick up from a local wrecking yard say maybe a pick and pull or something for real cheap...
Old Feb 28, 2005 | 02:32 AM
limpy's Avatar
Default Re: wut would i need to change my cable clutch to hydrolic clutch? (jdmcivicturbo)
http://hasport.com/Products/Mo...2.htm
buy that it comes with everything you need to swap to hydro from cable (everything but the tranny obviously.)
silverskateEF9
Feb 21, 2008 11:45 PM
lilo_goki
13
May 9, 2007 10:34 AM
NSfit
Oct 11, 2006 04:29 PM
ekVtecPower
Apr 16, 2006 05:53 PM
som3on3_10
11
Dec 25, 2004 12:47 PM
