FPR problems
b16a2
ive got the B&M FPR and its running at like 48psi and 50+ when unpluged
my air/fuel gauge stays way red and way lean until about 3k rpm's..
stock psi is what? around 38?
No you can adjust it either way
i got it tuned awhile ago but just recently has it been running so high
b16a2
p&p head
3 angle valve job
AEBS intake manifold
AEM cia
AEM fuel rail
4-1 header
HKS cat back
test pipe
AEM cam gears/pully
Gude stage 2 cams
B&M FPR
62mm bullfrog TB
ECU - jdm p30 (FOR SALE)
b16a2
p&p head
3 angle valve job
AEM cia
AEM fuel rail
4-1 header
HKS cat back
test pipe
AEM cam gears/pully
Gude stage 2 cams
B&M FPR
62mm bullfrog TB
nychonda
Aug 28, 2014 03:02 PM
Is the motor stock? What ecu? What mods to the motor if any?
