rpm goes 1000 to 4000 to 1000 to 4000 help!!
Old Feb 27, 2005 | 04:24 PM
55rezntogofst's Avatar
Default rpm goes 1000 to 4000 to 1000 to 4000 help!!
I think it might be an exhaust leak but not sure. No mods except JUN flywheel. Its a 94 gsr with 211,200 miles. My car is turned on, 1 minute later the rpm goes from 1000 to 4000 to 1000 to 4000 etc. I step on the pedal up to 5000 than it goes back to the 1000 to 4000 to 1000 etc. Any advice. Thanks guys.
Old Feb 27, 2005 | 04:27 PM
JdmH22Acorn's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (55rezntogofst)
idle air control vavle??? or tps im guessing
Old Feb 27, 2005 | 05:09 PM
Spoon ITR's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (JdmH22Acorn)
I'm willing to say the tps as well?
Old Feb 27, 2005 | 05:31 PM
GSR_Jamee's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (JDMDC2GSR)
i think its the IACV
Old Feb 27, 2005 | 05:38 PM
what is tps?
Old Feb 27, 2005 | 06:32 PM
Johnny_Rocket's Avatar
Throttle Position Sensor
Old Feb 27, 2005 | 07:59 PM
B20TDC2's Avatar
sounds like the fast idle thermo valve to me i had the same problem a couple weeks ago (surging idle) its an easy fix . remove the throttle body and underneath it is the fitv remove it and inside screw in the white piece(it backs itself out , bad design that honda did away with a few years later) replace everything and that should do the trick
Old Feb 27, 2005 | 08:14 PM
h22teg's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (B20TDC2)
idle surging sux could be TPS or maybe even somthing wrong with ur ecu
Old Feb 27, 2005 | 08:22 PM
fullthrottle35's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (h22teg)
its the iacv. it happens to lots of hondas. just take it off, spray it out with carb cleaner and put it back on.
Old Feb 27, 2005 | 09:12 PM
My Db2 AinT JDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">sounds like the fast idle thermo valve to me i had the same problem a couple weeks ago (surging idle) its an easy fix . remove the throttle body and underneath it is the fitv remove it and inside screw in the white piece(it backs itself out , bad design that honda did away with a few years later) replace everything and that should do the trick</TD></TR></TABLE>im with him..i fixed mine....make sure tighten that plastic screw like well...
Old Feb 27, 2005 | 09:30 PM
SoEvoL's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (InTeGrA_TyPe_Gs)
could be thermal valve, thats what was wrong with mine
Old Feb 28, 2005 | 07:26 PM
creationz's Avatar
Default Re: rpm goes 1000 to 4000 to 1000 to 4000 help!! (JDMCrx89)
i didnt replace my iacv i simply screwed the plastic ring inside back it and put a few drops of lock tight and i was good and ready to go..
Old Mar 2, 2005 | 05:33 PM
eluder33's Avatar
locktite +plastic =melting plastic, not a good idea at all!!
Old Mar 2, 2005 | 08:49 PM
inovative91's Avatar
either the fitv or check for vaccum leaks.
Old Mar 3, 2005 | 07:08 AM
DSR!'s Avatar
There could be something wrong with your gauge
Old Mar 3, 2005 | 02:27 PM
B20TDC2, thanks man, that was the trick. Took 2 days to do, cause of work schedule, but I got it to work. A million thanks.
Old Mar 27, 2005 | 10:36 PM
derrick2237's Avatar
I just did mine (FITV). Took about 1 hour working at a slow pace. The hardest part was taking off the coolant lines. I think loctite would of been great if I had any around. Thanks guys! I knew if i took it to a local mechanic, they would of probably charged $150+ for that.
Old Apr 5, 2005 | 06:20 PM
delsolgsrjackson's Avatar
Help!!!!!!!!!!!!!!!!!!!!!!!!!
i have done everything in this thread and no luck.
new iacv, new throttle body/tps, tightened the white plastic ring in the fast idle, sprayed starter fluid everythere and no surges.......help!!!!!
the only code that every comes up is heated O2 sensor and that is new as well....light not on right now, every now and then.
i have a b18c1 jackson raceing supercharged all new hoses, injectors, .....list goes on.. but i cannot figure out this surging problem
any help is greatly appreciated!
okkritikos
Dec 17, 2010 03:22 PM
takeit
Sep 11, 2007 06:31 PM
94Integra_Ls
Feb 14, 2007 10:01 PM
OriginalFive
Honda S2000
11
Jul 11, 2005 01:46 AM
