B18C GSR with CTR pistons- compression ratio?
Old Feb 27, 2005 | 02:32 PM
JDM_Spec's Avatar
Default B18C GSR with CTR pistons- compression ratio?
i got a 94 GSR b18c and i want to put some CTR or ITR pistons in. i wanting to clarify what the compression is. i have heard many stories. what is the c ratio for a stock b18c with ctr or itr pistons, also will i need to get it tuned or anything.eg new injectors? it will be runnin on 96-98 octane all the time?
Old Feb 27, 2005 | 03:00 PM
LSvtec03's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (JDM_Spec)
gsr w/ ctr pistons - 12.042422511586594:1
gsr w/ usdm itr pistons - 10.836228641070214:1
gsr w/ jdm itr pistons - 11.362493622638828:1
c-speedracing.com compression calculator
Old Feb 27, 2005 | 05:09 PM
BlueIntegraBoy's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">gsr w/ ctr pistons - 12.042422511586594:1
c-speedracing.com compression calculator </TD></TR></TABLE>
Nice... Figured out my compression (11.75:1)
Old Feb 27, 2005 | 05:18 PM
arw321's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (BlueIntegraBoy)
Holy ****, guys, come on. THis is getting a little crazy.
THE CSPEED CALCULATOR IS WRONG.
CTR pistons in a GSR motor, unmilled/undecked and oem 3 layer hg is damn near 13:1.
This has been covered on here about 3 or 4 times in that past 2 weeks alone.
Old Feb 27, 2005 | 05:33 PM
Nextelbuddy's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (arw321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arw321 &raquo;</TD></TR><TR><TD CLASS="quote">Holy ****, guys, come on. THis is getting a little crazy.
Old Feb 28, 2005 | 12:34 AM
JDM_Spec's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (Nextelbuddy)
how r u shall that it is 13:1?
Old Feb 28, 2005 | 02:53 AM
JDMGSR EG's Avatar
ive got a gsr block with ctr pistons and ive had my compression figured at 13.1 so ya you might be able to get away with no tuning if you run nothing less than 96 and just watch for detination on your motor DUNDADA
Old Feb 28, 2005 | 05:16 AM
aron0903's Avatar
i have ctr pistons in my gsr and my car is running great man. i do also have hondata but othere than that ud b ok. go for it man, you'll be satisfied.
Old Mar 31, 2005 | 09:08 PM
opiumdaze's Avatar
Default Re: (aron0903)
how can that calculator be acurate when not knowing the deck clearance and if the head has been milled? and also bore and piston size? I wouldn't say that it is completely accurate unless ur using it for just a refernce
Old Apr 3, 2005 | 10:09 AM
fullteg's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (JDMGSR EG)
WHEN U DID YOUR COMPRESSION TEST WHAT SHOWED UP ON THE GAUGE 270,280, U CAN EMAIL ME AT BOUNC00@AOL.COM THANK U
Old Jun 6, 2005 | 09:48 AM
JDM KING's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (fullteg)
Man I have a gsr with ctr pistons running on 91 octane and a spoon reflash, thing still gets about 250miles to a full tank
Old Jun 6, 2005 | 09:51 AM
Lan's Avatar
Lan
Default Re: B18C GSR with CTR pistons- compression ratio? (allmotordc2integ)
Your motor runs good on 91?
Old May 30, 2006 | 01:08 AM
2slowGs-R's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (Lan)
i want to know too since im about to purcahse a short block with ctr pistons and i believe an ls cranksahft!
Old May 30, 2006 | 01:40 AM
dohcMONSTER's Avatar
Default Re: B18C GSR with CTR pistons- compression ratio? (2slowGs-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM KING &raquo;</TD></TR><TR><TD CLASS="quote">Man I have a gsr with ctr pistons running on 91 octane and a spoon reflash, thing still gets about 250miles to a full tank </TD></TR></TABLE>
check my sig for my 91 octane GSR motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slowGs-R &raquo;</TD></TR><TR><TD CLASS="quote">i want to know too since im about to purcahse a short block with ctr pistons and i believe an ls cranksahft! </TD></TR></TABLE>
the LS crank puts it over the top on that one, with the 87.2 mm crank its already pushing it....
OrangeTeggy
11
Jan 7, 2010 07:32 AM
lickety_britches
Mar 21, 2008 07:31 PM
GSR_hatch936
11
Jan 10, 2008 12:06 PM
dayaftertomorrow
Jan 23, 2006 12:20 AM
Drian
Feb 22, 2004 09:24 PM
