Tranny Leak ?
Old Feb 27, 2005 | 01:01 PM
TyPe-R6's Avatar
Modified by TyPe-R6 at 3:33 PM 3/8/2005
Old Feb 27, 2005 | 01:10 PM
Jon D's Avatar
Default Re: Tranny Leak ? (TyPe-R6)
Find out whats going on before you start spending $$$ on a new case. Jack your caR up and get under there to see where the fluid is coming from. If the case just has fracture you can JB weld it. Now if there is actually a hole you could also have that fixed by any weld shop depending on how bad it is. When i was pricing new cases i believe both halves came to around $375 together with shipping, i opted to have it fixed by a weld shop for $35....so do yourself a favor and find out whats really going on first!
Old Feb 27, 2005 | 01:20 PM
TyPe-R6's Avatar
Default Re: Tranny Leak ? (Jon D)
ok...thanks for some 4-1-1
Old Feb 27, 2005 | 01:29 PM
Jon D's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TyPe-R6 &raquo;</TD></TR><TR><TD CLASS="quote">ok...thanks for some 4-1-1 </TD></TR></TABLE>
yeah not a problem......and there may not be a hole at all, but i was rather just kind of giving you advice based off of my own previous experience! Let us know though....as i am interested to hear what took place!
Old Feb 27, 2005 | 02:27 PM
TyPe-R6's Avatar
will do
Old Feb 27, 2005 | 02:54 PM
Mr Boston's Avatar
Make sure its not leaking from the axle seal! I had my clutch replaced before and my tranny leaked also and that was the culprit
Old Feb 27, 2005 | 06:16 PM
B2FiNiTY's Avatar
Default Re: Tranny Leak ? (Boston)
Most likely, it is from the axle seal.
Old Feb 27, 2005 | 06:17 PM
Kicker773's Avatar
Default Re: Tranny Leak ? (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Most likely, it is from the axle seal. </TD></TR></TABLE> yep
Old Feb 28, 2005 | 05:02 AM
TyPe-R6's Avatar
Default Re: Tranny Leak ? (Kicker773)
ok i will check that today....
Old Mar 4, 2005 | 05:47 AM
TyPe-R6's Avatar
I fixed the problem.....it was the axle thanks for the help guys
dc2long
Aug 25, 2007 09:32 PM
Pete_SI
18
Jul 28, 2005 05:47 AM
stockegsix
16
Sep 16, 2004 08:17 PM
jerbear!
Mar 16, 2004 09:47 AM
civicmon
10
Nov 17, 2003 03:54 PM
