How do you get the tps off of my car..
Old Feb 27, 2005 | 04:32 AM
88turdbucket's Avatar
Default How do you get the tps off of my car..
Do i have to buy a whole new tb or is there some way to get it off without having to buy a tb.. thanks for the help...
Old Feb 27, 2005 | 05:30 AM
crxnj's Avatar
Default Re: How do you get the tps off of my car.. (88turdbucket)
Use a dremel or sharp saw,or something and put a slot into the two bolts ..Then use a flat-head screwdriver to remove....
Old Feb 27, 2005 | 05:37 AM
Default Re: How do you get the tps off of my car.. (Mr.speaker)
mine doesnt have 2 bolts it has what looks like one stud with a lock washer or a c clip.. and there is only one and its the dx version thanks
Old Feb 27, 2005 | 05:39 AM
Trance minister's Avatar
Yes those are what he means by bolts. What looks like riverts of some sort are actually screws. If you put a small notch in them you'll be able to unscrew them with a screw driver. If they still don't budge, you might be looking at grinding the heads off and removing the TPS that way, then removing the left over screws using a pair of vice grips.
Old Feb 27, 2005 | 06:09 AM
Default Re: How do you get the tps off of my car.. (Trance minister)
this sounds like so much fun i can barely wait thanks for the help
RangerRingor
Feb 12, 2013 03:55 PM
Evasion
Aug 20, 2010 05:37 PM
cehcivic15
Aug 14, 2009 01:56 AM
SHG_Claudio
Jan 8, 2009 02:47 PM
aaj23
Jan 31, 2005 10:45 PM
