Buying rear disc conversion: need help
Old Feb 26, 2005 | 05:43 PM
AThiker's Avatar
Default Buying rear disc conversion: need help
I'm picking up a rear disc conversion tomorrow. It does NOT include parking brake cables or brake lines. In these pics the calipers are not pictured but are included.
Is this everything I need except for calipers, brake lines, and e-brake cables? Just want to make sure its not missing a braket or something important.
TIA
Old Feb 26, 2005 | 05:51 PM
.BigSexy's Avatar
most hood white kid
wont you need a bigger master cylinder and a prop valve?
Old Feb 26, 2005 | 06:03 PM
AThiker's Avatar
Default Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">wont you need a bigger master cylinder and a prop valve?</TD></TR></TABLE>
Yes, good call. Forgot to mention I'm getting a 4040 non-abs prop valve, and a 91 civic EX master cylinder.
Other than those is that everything I need as far as the "trailing arm assembly"?
Old Feb 26, 2005 | 06:11 PM
A.E Motoring's Avatar
Default Re: (AThiker)
i'm sure u can get a prop valve and a new mc...when i did my JDM gsr rear disk...never put any of those on....and it still worked great...so much better than just having disks on the front...oh and btw it was on a 95 DX
Old Feb 26, 2005 | 06:16 PM
AThiker's Avatar
Default Re: (SPNFEDEJ)
Thanks for the responses. I've just got an odd feeling that there is a bracket or something that the caliper mounts to that isn't there
Old Feb 26, 2005 | 06:21 PM
how come the caliper is not on there?
Old Feb 26, 2005 | 06:30 PM
AThiker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">how come the caliper is not on there?</TD></TR></TABLE>
Not sure, but I was told it is included.
What's this piece circled in red?
Is it missing this piece?
Old Feb 26, 2005 | 06:40 PM
not really sure wat that piece is...i would have to look at mine...but wat car are these coming off of?
Old Feb 26, 2005 | 06:43 PM
AThiker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote">not really sure wat that piece is...i would have to look at mine...but wat car are these coming off of?</TD></TR></TABLE>
95 GSR
Old Feb 26, 2005 | 06:59 PM
pdiggitydogg's Avatar
That thing circled is just a shield.
As long as the caliper and bracket is included, you'll need the mc and cables as mentioned, along w/ rear disc lines from something.
...it doesnt matter what car theyre from...rear disc from everything is the same
Old Feb 26, 2005 | 07:26 PM
Default Re: (pdiggitydogg)
yup...u can get brake lines from a 91 integra i believe...i got those from a junk yard for like 20 bucks..
Old Feb 27, 2005 | 02:10 AM
AThiker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">That thing circled is just a shield.</TD></TR></TABLE>
Is it a necessity or can I get away with out it? Better yet, can I get it off my stock drum trailing arms?
Thanks for all your help people.
Old Feb 27, 2005 | 02:41 AM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AThiker &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks for all your help people.</TD></TR></TABLE>
It is a dust shield that goes over the parking brake cable connections on the rear disks... they aren't on your drums most likely - at least not on my 96 CX - and no u don't need them.
Old Feb 27, 2005 | 02:44 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (nub.96ek)
you don't need the dust cover, but be sure not to bend it. i made the mistake of setting the trailing arm on the ground too hard and it bent the dust cover, and where it buckled, it scraped into the rotor.
Old Feb 27, 2005 | 03:01 PM
AThiker's Avatar
Default Re: (AzntaggeR)
Thanks for all your help. I picked them up today and they look great. He even threw in GSR rear LCA's and the GSR booster/master cylinder at no extra charge
Old Feb 27, 2005 | 03:12 PM
.BigSexy's Avatar
most hood white kid
dang...now all u need are prolly new rotors and pads, prop valve, and lines and ull be set right?
Old Feb 27, 2005 | 03:37 PM
MrTodd's Avatar
So... What about the e-brake cables? Will the original Drum cables work fine, or do you need cables specifically for the discs?
Old Feb 27, 2005 | 03:43 PM
.BigSexy's Avatar
most hood white kid
when I said lines, I meant cables as well....I have been told to replace them all.....not to hijack this dudes thread, but where did u buy the conversion at?? I am going to be doing it soon, but the description on passwordjdm.com isnt very descriptive
Old Feb 27, 2005 | 04:19 PM
jdmeg9's Avatar
make sure you got the right master cylinder gsr is a abs car
Old Feb 27, 2005 | 04:23 PM
Jonathan_ED3's Avatar
Those look like they came from a big brake kit.
you better make ABSOLUTELY sure it has the necessary bracket with it. Without that, those rotors are worthless.
Old Feb 27, 2005 | 04:49 PM
BlueIntegraBoy's Avatar
Default Re: (MrTodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrTodd &raquo;</TD></TR><TR><TD CLASS="quote">So... What about the e-brake cables? Will the original Drum cables work fine, or do you need cables specifically for the discs?</TD></TR></TABLE>
Cables from 92-95 EX/Si, Integras, Del Sol VTECs, 99-00 Si works.
Old Feb 27, 2005 | 05:05 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (jdmeg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">make sure you got the right master cylinder gsr is a abs car</TD></TR></TABLE>
Get the MC from a NON-ABS RS or GS teg.
Old Feb 27, 2005 | 05:14 PM
AThiker's Avatar
Default Re: (swapped and still slow)
Yes I realize I need a non-abs master cylinder without reflaring brake lines.
As for the brackets, they're on there and he showed me how to take them off to put stock rotors back on
I'm going to try to find e-brake cables from a 92-95 civic Si or any integra for that matter and a 4040 prop valve from a non-abs integra; either one from a 90-93 or one from a 94-01 RS.
Got them from a guy who was parting out a wrecked GSR.
fryman
Aug 7, 2015 06:49 PM
j me4door
Mar 6, 2009 07:06 AM
88LSCRX
Jun 19, 2008 06:29 PM
accordOnVolks
Jun 30, 2005 10:38 PM
Evil EG
Dec 14, 2003 07:01 PM
