88 honda civic head gasket
Old Feb 26, 2005 | 03:27 PM
jaw174's Avatar
Default 88 honda civic head gasket
hey there. i have an 88 civic DX. the headgasket has leaked coolant into the cylinders, and the car is no longer operatonal.
anny suggestions as to the procedure/ additional things to watch for /replace when i take it apart? it has 145k miles, so i will probbaly replace the timing belt, since ill be in ther anyways. anything else?
Old Feb 26, 2005 | 06:59 PM
acuratech's Avatar
Default Re: 88 honda civic head gasket (jaw174)
It is pretty simple. Unbolt everything from the head, including the intake manifold. Slip off the timing belt, remove the valvecover, and unbolt the head. I have pulled several of these heads like this, takes me about a half hour to tear it down...
Old Feb 26, 2005 | 07:40 PM
kulangot's Avatar
Default Re: 88 honda civic head gasket (acuratech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuratech &raquo;</TD></TR><TR><TD CLASS="quote">It is pretty simple. Unbolt everything from the head, including the intake manifold. Slip off the timing belt, remove the valvecover, and unbolt the head. I have pulled several of these heads like this, takes me about a half hour to tear it down...</TD></TR></TABLE>
and change the water pump, timing belt, plugs, intake manny gasket and make sure you take it off in the rite sequence...
Old Feb 26, 2005 | 10:24 PM
square_1's Avatar
Yeah... I agree with the water pump too. I had mine replaced at 144K. They will go bad sooner or later, and might as well replace it while in the process of all the other junk.
jermo
Honda Civic (2001 - 2005)
Jul 30, 2014 02:26 PM
zcmotor
10
Apr 15, 2008 08:37 PM
h2point2
Apr 20, 2007 06:58 PM
r3sgtec
Sep 2, 2006 07:42 PM
