Car wont start. PLEASE HELP!
was going to go get gas this morning but when getting in my car and trying to start it, it would just crank over but wouldnt start. i checked everything but came to the conclusion it was my ignition coil so i went and bought a new one, installed it but it wouldnt start again. i pulled my spark plugs out to check and they didnt seem to look "wet" so i got my friend to try starting it without number 1 spark plug in. i had a flashlight seeing if i was getting fuel in the cylinder but it didnt seem like it so now i think its my fuel pump. if you have experienced this or know how i can fix my situation please let me know. thanks
did you ever check ur distributor coil for spark, don't assume like i have. i'm in the same situation ur in but i know i'm not getting any spark??? get a helms manual and it'll tell u how to check it, or even a chiltons.
i just checked my ignition coil for resistance and its getting .8ohms primary and 15.5ohms secondary. i also checked my ignition control module to see if it was getting bettery voltage and i got 10.52V which seems reasonable.
i had similar problem bfr
take one spark plug out and let it crank and see if it sprays fuel out of the hole
or
crack a little and then take one spark plug and look and smell for fuel
let me know if you are getting it or not
or
