dilemma:swap pistons or build head
Old Feb 26, 2005 | 11:06 AM
johnzm's Avatar
Default dilemma:swap pistons or build head
im picking up a cherry GSR shorblock, and according my #'s if i do a 2 layer headgasket, millt eh head 10-15tho and do flatfaced valves i can get into the 11's in compression. should i do all that or swap the pistons out to JDM R, and 2 layer+valves?
BTW my only reservation for keeping the bottom end the way it is, is that its a 01 with only 36k on it- still new!
Old Feb 26, 2005 | 11:23 AM
Infinite Auto's Avatar
Default Re: dilemma:swap pistons or build head (johnzm)
thats not even a good question, high compression will get you nothing if you cant take advantage of it......headwork for sure
Old Feb 26, 2005 | 11:46 AM
accorse07's Avatar
spend your money on the head...
Old Feb 26, 2005 | 11:48 AM
Y2K Si FBP's Avatar
voted headwork...people are making some crazy power on stock blocks. honda's design is all in the head...unless u want full out race motor i wouldn't swap internals in the block just yet.
Old Feb 26, 2005 | 02:06 PM
johnzm's Avatar
Default Re: dilemma:swap pistons or build head (Y2K Si FBP)
SORRY i didnt make this more clear, the question is more suited to where to get the compression from, the stock GSR is 10:1 from the factory, with my b16 head on it the compression willbe ~9.8:1!
i am not doing headwork like porting but i will be doing headwork as in milling and valves to get the compression i want. buti im not sure if the flat tops are the way to go or the light dome of the jdm itr
Old Feb 26, 2005 | 06:34 PM
Rocket's Avatar
Headwork from Don for you Atlanta guys.
Old Feb 26, 2005 | 09:16 PM
Ketone's Avatar
Default Re: dilemma:swap pistons or build head (Rocket)
i think you should do the head-work first.
Old Mar 10, 2005 | 09:06 AM
accorse07's Avatar
if your gonna mill hte head might as well port the head as well...i would suggest going only 15 over and welding the chambers on the head so it will have the characteristics as a gsr in the port...while your at it swap in itr intake valves...relatively cheap and has a better flow angle once the head is ported and milled...with stock bottum end and the mill you should be able to get 10.4-10.6 compression...try removing a layer from your stock head gasket as well...
Old Mar 11, 2005 | 04:19 PM
ArinX's Avatar
itr pistons dont cost much, Block isnt in the car yet. and if you do the work your self why not?
Im not saying dont do the headwork, pretty easy to take the head off later.
BLU CIVIC
11
Nov 3, 2009 05:35 AM
Nextelbuddy
May 9, 2005 07:42 PM
vti2
Jul 5, 2004 08:13 PM
jeremy.
Jul 13, 2003 08:31 AM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
