Rod knock on D16Z6 SI hatch 95????
i just got my hatch out of the body shop and nowit has rod knock i think.....does this mean it has a spun bearing???i really don't want this car unless it's not too much of a hassle to replace bearings someone let me know what else it could be
if it has spun a bearing, the oil light should be on, and if it is spun and on, new bearings will not fix it. you need to re-size the big end of the rod and machine the crank. put a manual oil pressure gauge on it and see where the oil pressure is. and go from there.
what is rod knock? can u hear it? hows it sound? let me know...i have a funny sound when i tap on the gas when im at idle...only happens at idle...when i put my stock obd2 ecu it doesnt have that sound...only happens when i have my chipped p28 in...
iwannarace
10
Jun 13, 2015 06:14 AM
myEK=slow
Apr 18, 2008 04:37 AM
