Weird Steering wheel vibration...please help!
Old Feb 25, 2005 | 10:51 PM
Weapon_R's Avatar
Default Weird Steering wheel vibration...please help!
Hey guys...
I just installed my summer wheels tonight. Well, I KNOW that these wheels were straight when I took them off last year.
I started up the car, and backed out. Steering wheel felt a little different, but no big deal.
As soon as I started forward, however, the steering wheel shakes from left to right constantly - at any rate of speed.
Does anyone have any suggestions? It started ONLY after I put the wheels on.
Old Feb 25, 2005 | 10:55 PM
Hatchamaback's Avatar
make sure all of the lug nuts are tight on, then after about 50 miles make sure their tight again and you should be good. I had a similar problem i thought it would be the wheel bearing or axle but it was just the wheel.
this may not be in the subject but make sure tire rotation is facing the correct way too . hope taht helps.
Old Feb 25, 2005 | 10:59 PM
.BigSexy's Avatar
most hood white kid
get your tires balanced.....that is probably your problem.....but it could be an alignment issue....i have the same problem, and I know I need new tires, alignment, and balance and rotation, and my car will jar you loose at 70
Old Feb 25, 2005 | 11:00 PM
Weapon_R's Avatar
Default Re: (conFusedEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by conFusedEG &raquo;</TD></TR><TR><TD CLASS="quote">make sure all of the lug nuts are tight on, then after about 50 miles make sure their tight again and you should be good. I had a similar problem i thought it would be the wheel bearing or axle but it was just the wheel.
this may not be in the subject but make sure tire rotation is facing the correct way too . hope taht helps.</TD></TR></TABLE>
Thanks for your help. I did confirm that the tire rotation is correct.
When you say that it was just the wheel, what do you mean? How did you fix it?
Tomorrow i'm going to jack up the front and retorque the lugnuts.
Old Feb 25, 2005 | 11:04 PM
Not sure My right front wheel acted up and tugged my steering wheel to the right when i starting moving. So i just too the rim off hand tightened, then impacted the bitches in and it worked fine.
If it persists after that fix explain more in depth, such as if you have bad axles etc, anything suspension wise and we can help you out. Good luck.
Old Feb 25, 2005 | 11:08 PM
130R's Avatar
could be a many number of things like tires improperly inflated... loose bolts... wheels aren't balanced... wrong alignment...
Old Feb 25, 2005 | 11:09 PM
Weapon_R's Avatar
thanks again for the help. I'm 110% sure that nothing has gone bad. Remember, the problem happened ONLY after i put the rims on. 20 mins earlier, when I had the steelies on, it drove perfectly.
DawgC2
Suspension & Brakes
12
Dec 11, 2011 05:01 PM
cash459
Acura TL, RL & ZDX
Aug 18, 2008 02:56 PM
soeurm
Jul 30, 2007 03:02 AM
raynaud
Aug 31, 2004 02:20 PM
B00ST2nR
Dec 27, 2003 07:32 AM
