just got Vision oil catch can...about to install but....
Old Feb 25, 2005 | 07:53 PM
bennjamin@ozhonda.com's Avatar
Default just got Vision oil catch can...about to install but....
....some things are puzzling me.
For example , the pipign will run from PCV , to the can inlet , then another hose will contuinue back to the inlet manifold . All fine and dandy. But , how do i remove the piping from the PCV and oinlet manifold easily / without damaging it? After removing the small clips , it will not budge with any effort ?!? Any hints ?
Also , is this catch can internally baffled / filtered inside ?
If not , is there a good DIY way to insert some steel wool etc ?!?!?
Any guides...cheers Ben
Old Feb 26, 2005 | 03:59 AM
Default Re: just got Vision oil catch can...about to install but.... (bennjamin@ozhonda.com)
anyone got any ideas ?
Old Feb 26, 2005 | 04:14 AM
boostedcivicsir's Avatar
Mr. Badwrench
get a pick tool and some wd40. get under the hose and hit it with the wd and it should slide right off. as for if it is baffled or not i am not sure.
Old Feb 26, 2005 | 06:12 AM
Frozen E's Avatar
H-T White Ops
don't use steel wool. It'll corrode and go to **** on you. I've heard of plenty of people actually using loofas (those shower things) and sticking them in there.
Utilitarian
Nov 30, 2012 11:25 AM
schpiel
Jul 9, 2007 08:57 PM
turbotime
Sep 30, 2005 11:26 AM
nerdsports
Feb 7, 2003 07:05 AM
citanest
Jan 17, 2002 06:24 AM
