P0505 Idle Control System Malfunction
Old Feb 25, 2005 | 06:47 PM
TurboEM1's Avatar
Default P0505 Idle Control System Malfunction
Hey guys my 99 Si is throwing this code. I erased it but it came back an hour later. How do i got about fixing this? What part should I buy? How much?
Also is it safe to do some minor driving untill i fix it?
Old Feb 26, 2005 | 04:32 PM
TurboEM1's Avatar
Default Re: P0505 Idle Control System Malfunction (TurboEM1)
bump, i need help
Old Feb 26, 2005 | 05:20 PM
civic-si-2000's Avatar
your iacv is either dirty or bad. Pull it off and clean it with some carb cleaner and put it back on. If that doesn't fix it than you'll have to buy one and they are fairly expensive.
Just in case you don't know the iacv is located on the back side of the intake manifold. It has 2, 12mm bolts, an electrical connector, and 2 hoses'. pull it off and clean it.
Old Feb 26, 2005 | 09:10 PM
TurboEM1's Avatar
Default Re: P0505 Idle Control System Malfunction (civic-si-2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-si-2000 &raquo;</TD></TR><TR><TD CLASS="quote">your iacv is either dirty or bad. Pull it off and clean it with some carb cleaner and put it back on. If that doesn't fix it than you'll have to buy one and they are fairly expensive.
Just in case you don't know the iacv is located on the back side of the intake manifold. It has 2, 12mm bolts, an electrical connector, and 2 hoses'. pull it off and clean it. </TD></TR></TABLE>
Thanks so much for the reply. I most likely can find it myself but are there any links with pics or a how to? Thanks again
Dizayne
14
Mar 5, 2008 06:54 AM
TheWelderGuy
Apr 2, 2006 10:24 AM
h23a1pimp
Dec 6, 2005 04:08 PM
972drcordex
Jul 4, 2004 04:34 PM
SiR HatchAlot
Oct 22, 2003 03:52 PM
