del sol engine swaps
Old Feb 25, 2005 | 06:41 PM
project civic's Avatar
Default del sol engine swaps
I was wondering what the cheapest engines i could swap into my 93 del sol with out aftermarket motor mounts. Im alos doing a auto to manual transmission conversion.
Old Feb 25, 2005 | 06:46 PM
HATCHingMN's Avatar
Default Re: del sol engine swaps (project civic)
you will need to convert to Delsol VTEC configure for all B-series engine swap. It should be easy.
Old Feb 25, 2005 | 06:51 PM
BlueIntegraBoy's Avatar
D-series will always be cheaper and you could use stock mounts, but you would need a new tranny mount.
Old Feb 25, 2005 | 07:34 PM
delslo93's Avatar
Default Re: del sol engine swaps (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">D-series will always be cheaper and you could use stock mounts, but you would need a new tranny mount.</TD></TR></TABLE>
D-series all the way!! Only the d-series motors will allow you to use your stock mounts other than your tranny mount like posted earlier. Plus stuff for them is cheap as hell. A d16z6 would be your best bet.
Old Feb 25, 2005 | 08:31 PM
jarrodholley's Avatar
what engine do you have now?
Old Feb 25, 2005 | 09:52 PM
d15b7 and as for the tranny mount im going to be using a hasport adapter mount for the manual tranny. Would the b18b be a good engine?
Old Feb 25, 2005 | 10:23 PM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project civic &raquo;</TD></TR><TR><TD CLASS="quote">d15b7 and as for the tranny mount im going to be using a hasport adapter mount for the manual tranny. Would the b18b be a good engine?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=878010
Old Feb 25, 2005 | 10:35 PM
KillBot's Avatar
Good brand name on the mount. Thats what I used.
Itzmy91Teg
May 4, 2007 08:32 PM
sprmnrcr17
May 23, 2006 06:57 PM
roosta 1
May 18, 2005 09:18 PM
legoman
Jan 27, 2005 10:31 AM
pakman2002
Jun 15, 2004 12:06 PM
