How do you TURN ON the CEL?
Hey I want to check if my CEL works and I have a feeling it doesnt. Is there a safe way to turn it on to check that it works. Car is a 99 Civic Si.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">It should light up just starting the car.
But if you want to create a cel, you can unplug the intake temp sensor or the primary o2...those seem the quickest to me</TD></TR></TABLE>
correct
correct
ok thanks for the replies. The CEL does come on when you first turn the key. Right now on my short ram intake it does not have a hole for the Intake Air Temp sensor so it is just in the engine bay and there is no CEL. To turn on the CEL i would have to take out the "tip" on the sensor correct? Thanks again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 »</TD></TR><TR><TD CLASS="quote">Right now on my short ram intake it does not have a hole for the Intake Air Temp sensor so it is just in the engine bay and there is no CEL. To turn on the CEL i would have to take out the "tip" on the sensor correct? Thanks again.</TD></TR></TABLE>
Having the IAT sensor loose in the bay wouldn't necessarily trigger a CEL (and in almost all cases won't), so if that's the reason you're concerned, don't be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">Is the temp sensor really necessary? I'v had mine dangling next to the intake for about a month with no problems
your a/f ratio is probably not optimal since it's just measuring under hood temps instead of the temp in your air intake system
</TD></TR></TABLE>your a/f ratio is probably not optimal since it's just measuring under hood temps instead of the temp in your air intake system
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">
Having the IAT sensor loose in the bay wouldn't necessarily trigger a CEL (and in almost all cases won't), so if that's the reason you're concerned, don't be. </TD></TR></TABLE>
Yea thats what i was concerned with
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTagTeam »</TD></TR><TR><TD CLASS="quote">Is the temp sensor really necessary? I'v had mine dangling next to the intake for about a month with no problems </TD></TR></TABLE>
Thats how mine is
Thats how mine is
Hey guys guess what. I was driving today and you know what happens? My check engine light came on and i didnt try to set it off. I checked the code and it threw a
P0505 Idle Control System Malfunction
I erased it but it came back about an hour later. What is wrong? What part should i buy? Check this thread out.
https://honda-tech.com/zerothread?id=1161900
Thanks
Thanks
sumoneEK
Nov 22, 2010 11:29 AM
