Need help wiring up race car
Old Feb 25, 2005 | 02:33 PM
eRACING's Avatar
Default Need help wiring up race car
I hate to through in a link towards another forum on this board (Tech Section - https://honda-tech.com/zeropost...61493) though I'm not gaining any info there... Since the car is a Drag Only car, I thought I'd ask those of you that have been through the experiance before, possibly many times.
To make my problem short and sweet, I finally found a 92 hatch that being built as my All Motor Drag Project... Problem is, the car has absolutely no, zero, nadda wiring so I'm starting from scratch.. My question is, what exactly do I need to buy to make the car functional? Obviously I need a engine harness, un-dash ecu harness, but what else? There's a lot of wires, fuse relays, etc. under a OEM dash so I'm reaching out for help / a parts to buy list... I know this is a long shot, though are there any companies out there that basically make a race type harness that has everything you need all in one?
Sorry the pictures aren't hugely detailed, but the car looks like this (no fuse boxes, no notta):
Old Feb 25, 2005 | 02:58 PM
speedworks's Avatar
Default Re: Need help wiring up race car (erics99si)
what engine management are you going to use.
Old Feb 25, 2005 | 03:13 PM
mrbsponge's Avatar
pm BLOWN90HATCH, on here, he makes full racecar harnesses!
check him out
Old Feb 25, 2005 | 03:55 PM
Blown90hatcH's Avatar
https://honda-tech.com/zerothread?id=1156493
Old Feb 25, 2005 | 05:28 PM
JSpin's Avatar
Default Re: Need help wiring up race car (Blown90hatcH)
seems to be a lot of this stuff going on
talk to jason/blown90hatch
Old Feb 25, 2005 | 05:49 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Need help wiring up race car (JSpin)
https://honda-tech.com/zerothread?id=1043518
There was a really good thread in drag racing but I cant find it.
art
Old Feb 25, 2005 | 06:25 PM
SpeedDreamz.com's Avatar
Default Re: Need help wiring up race car (Arturbo)
where are you located?
Old Feb 25, 2005 | 06:33 PM
eRACING's Avatar
Default Re: Need help wiring up race car (30psiCiv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedworks &raquo;</TD></TR><TR><TD CLASS="quote">what engine management are you going to use.</TD></TR></TABLE>
Hondata S200 w/ all the goodness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">pm BLOWN90HATCH, on here, he makes full racecar harnesses!
check him out</TD></TR></TABLE>
I'll PM him shortly.. Any pictures of this harness? Do you know what the harness includes? Thanks for the info!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv &raquo;</TD></TR><TR><TD CLASS="quote">where are you located?</TD></TR></TABLE>
Seattle, Washington area
Old Feb 25, 2005 | 07:24 PM
Supernatural's Avatar
hondata is very sensitive when it comes to race harnesses.....it needs stuff like the load detector and a bunch of other bullshit.....unless hondata is different now your gonna have a headache with a race harness and hondata
Old Feb 25, 2005 | 07:32 PM
Default Re: Need help wiring up race car (SUPERNATURAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SUPERNATURAL &raquo;</TD></TR><TR><TD CLASS="quote">hondata is very sensitive when it comes to race harnesses.....it needs stuff like the load detector and a bunch of other bullshit.....unless hondata is different now your gonna have a headache with a race harness and hondata</TD></TR></TABLE>
You can disable the ELD in hondata. I have not had any problems running the race only harness. All the appropriate sensors are still there for the Hondata to function correctly in the way I set them up.
Old Feb 25, 2005 | 07:42 PM
bracket 4 life's Avatar
Old Feb 25, 2005 | 07:57 PM
eRACING's Avatar
Default Re: Need help wiring up race car (infamousCW-hatch)
In ways I feel like I should put all the OEM hardware in the just to be sure I have everything needed My biggest concern about this project so far is not knowing what "exactly" I need to allow the car to run properly... I'm very mechanical, etc.. though I've never started a car from bone scratch on up...
blown90hatch... I'm interested in your harness work as well... The car has all the OEM peices under the hood (brake/clutch master cyl., etc.. so I'd like a harness that'll run all of the OEM parts under the hood.. As far as interior wise, as long as the car starts when I turn the key I'm happy..lol the glass is full lexan now so theres no working windows, locks, lights, etc.. needed... So my entire problem is.. Where do I start?
Old Feb 26, 2005 | 06:15 AM
mrbsponge's Avatar
http://www.jkobd.com
this is blown90hatchs site he has a pic of a full racecar harness on there
Old Feb 26, 2005 | 05:56 PM
eRACING's Avatar
Default Re: (mrbsponge)
maybe someone out there has a picture of there interior without the dash... as well as under the hood.??
Old Feb 27, 2005 | 10:59 AM
Kataku2K3's Avatar
Default Re: (erics99si)
I've never had a problem with Hondata either, haven't done anything lately tho. Either way you shouldn't have any problem. Good Luck
Old Feb 27, 2005 | 11:59 AM
eRACING's Avatar
Default Re: (Kataku2K3)
so basically all I need to do is buy blown90hatch's race harness he has to offer and I'll be good to go? what about all the fuse boxes, etc...
Old Feb 27, 2005 | 01:38 PM
Kataku2K3's Avatar
I'm not sure about Jason's harnesses but, yea that's all you need. With mine all you have to wire up is a constant 12V+, main ground, starter input ground, and a main switched ground which powers everything up. The only reason I use negative triggers for all my relays is to ease in wiring.
Old Feb 28, 2005 | 06:22 AM
Arturbo's Avatar
Better than steak
25 Year Member
Here is the other post I was looking for:
https://honda-tech.com/zerothread?id=814559
Old Feb 28, 2005 | 11:36 AM
eRACING's Avatar
Default Re: (Arturbo)
k thanks... I'll look that link over
Old Mar 13, 2005 | 08:36 PM
eRACING's Avatar
WHO SENT ME THE PM ABOUT HAVING THE COMPLETE HARNESS THAT WE AGREED ON FOR $75??
I've misplaced your information and my PM history only shows the last 7 days worth... please pm me if your reading this..lol
Old Mar 13, 2005 | 08:56 PM
.dave's Avatar
i HAS questions ?
Just out of curiousity, how much is the materials only cost to make a wiring harness for a Honda using materials like the ones on the Motec site?
Old Mar 14, 2005 | 08:42 AM
regamaster's Avatar
Default Re: (1 cam)
Motec uses the best material. Most of their material is all MIL-spec. Some connectors will cost more then $100/each (depending on which ones) not to mention the time and tools to do the pinning.
Old Mar 14, 2005 | 10:11 AM
paulzy's Avatar
why not run an OBD2a civic harness with an OBD2a to OBD1 converter?
Old Mar 14, 2005 | 11:31 AM
Kataku2K3's Avatar
Default Re: (paul vang)
It's not the Mil Spec wire that's sooo expensive, it's the damn Raychem DR-25 shrink...
Old Mar 14, 2005 | 05:51 PM
bigTom's Avatar
then u add in the transitions, labels, boots, connectors... it adds up real quick
u can use connectors that go upwards of $200 a half
