B18C5 obd2b into a EG4!! Help!!
Old Feb 25, 2005 | 09:13 AM
khmoe's Avatar
Default B18C5 obd2b into a EG4!! Help!!
I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.
But what should i use on the ECU part. i'm getting the ECU from the same car, but can i use it with a wireing conversion harness??
Help me.
Old Feb 25, 2005 | 10:54 AM
tONE.steR's Avatar
* B A N N E D *
Default Re: B18C5 obd2b into a EG4!! Help!! (khmoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.
Help me. </TD></TR></TABLE>
Its completely plug and play.
Ecu is up to you, I would just go w/ a chipped p28 if you're on a budget. Unless you have the cash for hondata.
Old Feb 25, 2005 | 06:09 PM
00000xxx's Avatar
chipped p28 or get a obd1 to obd2b conversion harness from boomslang.com then wire up your knock sensor
Old Feb 25, 2005 | 06:27 PM
neeks's Avatar
Default Re: B18C5 obd2b into a EG4!! Help!! (ctr610)
i got a gsr obd2a going into a obd1 car..the ecu is obd1 p28 w/skunk2 program and i got a boomslang to hook it all up.....do it
Old Feb 26, 2005 | 02:44 AM
khmoe's Avatar
I have heard that the OBD2b ECU has a security key thing is that true, or not?
Were do i buy harness or a p28 that is chipped??
Thanx for replys
Old Feb 26, 2005 | 03:06 AM
tONE.steR's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe &raquo;</TD></TR><TR><TD CLASS="quote">I have heard that the OBD2b ECU has a security key thing is that true, or not?
Thanx for replys</TD></TR></TABLE>
Yes obd2b has immobilizer, I can remove it for you.
Harness.. most local import shops should stock them or here on the boards.
Some sponsors will hook you up w/ a complete setup.
Old Feb 26, 2005 | 03:31 AM
khmoe's Avatar
Default Re: B18C5 obd2b into a EG4!! Help!! (Vita-Soy)
how do i remove the. immobilizer?? is it a chip??
How do i get a sponsor to sponsor me with a harness and what i need?
Old Feb 26, 2005 | 07:12 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khmoe &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to buy a b18c5 from a itr 2000 JDM OBD2b, i have research and found out that the harnes from the motor should connect to the OBD1 in the car.</TD></TR></TABLE>
This is true however if you get a JDM swap the harness will be much harder to use since it's from a RHD car. You "should" get an OBD2 USDM GSR or ITR harness.
Wonk Unit
Feb 11, 2007 10:26 AM
4thgenx42
Jan 4, 2007 05:34 AM
CRXLST
13
Sep 25, 2004 07:32 PM
Danethomp
Apr 22, 2004 06:52 PM
GettaluvR
May 1, 2003 08:23 AM
