DA Integra A-arm on Si knuckle
Old Feb 25, 2005 | 08:37 AM
JapJunkie's Avatar
Default DA Integra A-arm on Si knuckle
I was wondering if this setup will work right? The Si front knuckles are in good condition and they are missing one A arm. Will installing DA A-arms work? Im thinking it might not and end up having to go pick some up (No$$$ ) Or will i just need to get an alignment? TIA any info is appreciated.
Old Feb 25, 2005 | 08:58 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: DA Integra A-arm on Si knuckle (JapJunkie)
the DA UCA are the wrong dimensions, get the correct parts.
stan
Old Feb 25, 2005 | 02:32 PM
JapJunkie's Avatar
Default Re: DA Integra A-arm on Si knuckle (Stan D)
any more info....
Old Feb 25, 2005 | 02:53 PM
they are bigger in every dimension, they will have problems fitting in the strut tower, the bolts would have to be modified to fit. static camber will be positive, the dynamic camber curver will change. in other words, get the right part.
stan
Old Feb 25, 2005 | 03:15 PM
JapJunkie's Avatar
Aight coo i just want to know why it doesnt work...
I just got done installing the a-arm on the Si knuckle and everythiing bolted up fine.. The problem is i cannot let go of the steering wheel when driving or else it will jerk hard to the left or right....
just to double check the A-arm is just the upper part of the kunckle which has the 2 bolts which bolt in from inside the engine bay? And u replace only this part if u get a front camber kit, right? Thanks again.
Old Feb 25, 2005 | 09:55 PM
JapJunkie's Avatar
ttt
Old Feb 26, 2005 | 12:02 AM
EL Vap133's Avatar
it is recommended that you use your stock crx/civic A arms.
Old Feb 26, 2005 | 07:36 AM
bagpipe goatee's Avatar
yeah, that means your caster is really messed up if it wrenches to the side.
Old Feb 26, 2005 | 10:47 AM
JapJunkie's Avatar
Aight coo thanks i found a junkyard out in Sunvalley that has them for $40, im gonna roll down there and try and low ball them for $20 and work my way up
phateless
Suspension & Brakes
Feb 3, 2018 02:53 PM
kartman5
Suspension & Brakes
Aug 19, 2008 10:01 AM
Dracomeister
Honda Civic (2006 - 2015)
May 4, 2008 12:21 AM
Silent Knight
15
Jan 5, 2006 02:04 PM
RTW DC2R
Aug 9, 2003 01:50 PM
