Removing Cruise Control..
Old Feb 25, 2005 | 08:10 AM
StealthSol's Avatar
Default Removing Cruise Control..
I have a '93 del Sol Si and the cruise control does not work so I am planning on taking it out. The 92-95 Civic is probably set up the same way. Anyone have a tutorial on how to remove the CC? Thanks
Old Feb 25, 2005 | 10:20 AM
platinum00's Avatar
Default Re: Removing Cruise Control.. (StealthSol)
remove the vac line from the back of the intake manifold. cap that off..
unbolt the CC Assembly
Done.
platinum.
Old Feb 25, 2005 | 11:45 AM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
Default Re: Removing Cruise Control.. (platinum00)
Cannot recall whether the Civic is the servo type of cruise control, you certain the cable doesn't go through the firewall attached to the accel pedal?
Old Feb 25, 2005 | 03:26 PM
sohcvtec1995's Avatar
just trace everything and start a pulling and unbolting. it wont be to hard.
Old Feb 25, 2005 | 03:28 PM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
Default Re: Removing Cruise Control.. (INVALID)
I know for a fact that there is a cable attached to the accelerator pedal as part of the CC assy.
TheCivicMafia
Jun 14, 2012 01:55 PM
sd_ej1
Dec 30, 2008 09:30 AM
broketuner-Sol_Si
Apr 19, 2008 09:21 PM
Scales817
Jul 1, 2007 06:00 PM
jdmsol
Nov 10, 2002 07:03 PM
