cant boost over 4 psi
Old Feb 25, 2005 | 06:33 AM
fro's Avatar
fro
Default cant boost over 4 psi
i just got my car back together last week and i now i have a problem with my boost. it wont boost over 4 psi and i was wonering if anybody had an idea. i think it might be a small leak somewhere. i double checked all the vacum hoses and all the lines coming to and from the turbo and there all fine. i was just wondering if anybody had an idea on what it could be.
Old Feb 25, 2005 | 06:36 AM
Evanmb44's Avatar
Default Re: cant boost over 4 psi (fro)
what wastegate spring are you running and are you running a boost controller. need to give some more information in order to help you out
Old Feb 25, 2005 | 06:43 AM
fro's Avatar
fro
Default Re: cant boost over 4 psi (Evanmb44)
i am running a 9 pound spring and no boost controller
Old Feb 25, 2005 | 06:59 AM
beepy's Avatar
How is the spool rate? Same as before or slower?
Probably a boost leak.
Old Feb 25, 2005 | 07:01 AM
B18C1CYA's Avatar
could be a exhaust leak b4 the turbo , or boost leak in the charge pipes
Old Feb 25, 2005 | 07:07 AM
fro's Avatar
fro
Default Re: cant boost over 4 psi (B18C1CYA)
thats what i am hoping for is that is a charge pipe. but i will look at it later tonite after i get off of work.
Old Feb 25, 2005 | 11:32 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">could be a exhaust leak b4 the turbo , or boost leak in the charge pipes </TD></TR></TABLE>
Old Feb 25, 2005 | 06:23 PM
fro's Avatar
fro
Default Re: cant boost over 4 psi (PrettyLude)
fixed it it was a boost leak in the charge pipe
Old Feb 25, 2005 | 08:39 PM
Beau Gotti's Avatar
are you running a FMU, and what injectors do you have, my buddy had a 6:1 FMU, and stock injectors and had the same problem
Old Feb 25, 2005 | 09:36 PM
PrecisionH23a's Avatar
Is the car popping around 4500-5000rpms?
It could be you are using the wrong plugs that are not gapped properly.
Old Feb 25, 2005 | 11:56 PM
TA Performance's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro &raquo;</TD></TR><TR><TD CLASS="quote">fixed it it was a boost leak in the charge pipe</TD></TR></TABLE>
Where or which charge pipe was it? cuz im only hitting 5psi and i have a 10psi spring! so i have same problem, it might be loose in the same area
Old Feb 26, 2005 | 07:41 PM
fro's Avatar
fro
Default Re: cant boost over 4 psi (USDMx05)
its actually a tear in the connecting piece from the trubo to the charge pipe so i have to replace it. it still does it sometimes it will boost and sometimes it doesn't. but i also think that it might be my waste gate because i dont hear it open at all.
Old Feb 26, 2005 | 08:53 PM
same here
Old Feb 28, 2005 | 08:21 PM
fro's Avatar
fro
Default Re: (USDMx05)
now that i got my charge pipe fixed now i have anothe problem. i have a 9 psi spring but i will go past that and i dont have a boost controller can anybody tell me why this is happening
Old Feb 28, 2005 | 08:25 PM
EJ1 wilcox's Avatar
Default Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro &raquo;</TD></TR><TR><TD CLASS="quote">now that i got my charge pipe fixed now i have anothe problem. i have a 9 psi spring but i will go past that and i dont have a boost controller can anybody tell me why this is happening</TD></TR></TABLE>
So, you are over boosting? How much? Is it just spiking or holding steady at a higher boost level?
I would be careful if I were you... overboosting can be the end of your motor
Old Feb 28, 2005 | 08:56 PM
fro's Avatar
fro
Default Re: (EJ1 wilcox)
im not for sure what it goes to but it was at 11psi and i backed off the gas. so i dont know if it stops there or keeps going.
Old Feb 28, 2005 | 09:03 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro &raquo;</TD></TR><TR><TD CLASS="quote">im not for sure what it goes to but it was at 11psi and i backed off the gas. so i dont know if it stops there or keeps going.</TD></TR></TABLE>
on a FMU...
Old Feb 28, 2005 | 09:04 PM
EJ1 wilcox's Avatar
Default Re: (Built B16A)
Maybe your wastegate is stuck or something... is it internal or external?
Old Feb 28, 2005 | 09:21 PM
5litereater's Avatar
wastegate is probably stuck. my buddy's t25 on his sr20 was doing the same thing.
Old Mar 1, 2005 | 06:25 AM
fro's Avatar
fro
Default Re: (5litereater)
i will check my wastegate tonite after work its an external wastegate and im runnuing a vafc. is it possible that the spring broke.
Old Mar 1, 2005 | 06:38 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (fro)
I bet it's fun though
Old Mar 1, 2005 | 06:55 AM
fro's Avatar
fro
Default Re: (stackz)
yeah its pretty crazy but im scared to blow my motor.
Old Mar 1, 2005 | 07:15 AM
EJ1 wilcox's Avatar
Default Re: (fro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fro &raquo;</TD></TR><TR><TD CLASS="quote">i will check my wastegate tonite after work its an external wastegate and im runnuing a vafc. is it possible that the spring broke.</TD></TR></TABLE>
I don't see how the spring could break but I would inspect the wastegate to make sure it's working properly...
Old Mar 1, 2005 | 07:21 AM
Hyaboosta's Avatar
might be sticking. Do you have a vac line connected to the top barb fitting of the wastegate?
Old Mar 2, 2005 | 08:04 PM
fro's Avatar
fro
Default Re: (Hyaboosta)
yeah
