buying a used hondata S200...will i need to buy ECU hardware?
Old Feb 25, 2005 | 02:15 AM
1.8's Avatar
1.8
Default buying a used hondata S200...will i need to buy ECU hardware?
ECU hardware. It includes two chips, socket, two resistors, and harness socket.
the seller is selling me just the hondata unit and the wire harness. will i need this?
Old Feb 25, 2005 | 03:12 AM
dustin's Avatar
Default Re: buying a used hondata S200...will i need to buy ECU hardware? (1.8)
You will need a socketed ecu...
Old Feb 25, 2005 | 11:33 AM
1.8's Avatar
1.8
Default Re: buying a used hondata S200...will i need to buy ECU hardware? (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">You will need a socketed ecu...</TD></TR></TABLE>
so none of that **** is nescessary? just get the hondata and wire harness and bring it to a place and get it socketed?
Old Feb 25, 2005 | 11:53 AM
dustin's Avatar
You need stuff like "It includes two chips, socket, two resistors, and harness socket." to socket/chip and ecu.
Old Feb 25, 2005 | 11:59 AM
dustin's Avatar
This is what you will need
http://www.moates.net/product_...id=42
Old Feb 25, 2005 | 12:00 PM
turbosi03's Avatar
yeah you need all the misc circuit components... isn't there a few ceramic capacitors also?
EDIT: yep I saw the caps in dustin's link above... freakin weird, how many damn dustins are on this forum?
Old Feb 25, 2005 | 12:26 PM
SoEvoL's Avatar
Default Re: buying a used hondata S200...will i need to buy ECU hardware? (turbosi03)
send u ecu off to hondata, they will do it for 65 including parts
Old Feb 25, 2005 | 01:09 PM
turbosi03's Avatar
Default Re: buying a used hondata S200...will i need to buy ECU hardware? (JDMCrx89)
pfft, screw that send it to me I'll do it for $15, it's not hard to do nor does it take long... if you can solder just do it yourself.
saemoonyang
Oct 4, 2014 11:31 AM
Simmerman
13
Jan 20, 2006 07:45 PM
Memo6453
May 1, 2004 12:26 PM
