Quick Cam Questions..
Old Feb 24, 2005 | 11:06 PM
hi mom's Avatar
Default Quick Cam Questions..
I have a 95 Integra LS with LS/VTEC
B16 IM
B16 TB
B16 Head
B18 Block blah blah.
Would it be worth it to swap the B16 cams for GSR cams?
Also, would I need to do valve springs and retainers to be able to throw in ITR cams? A friend of mine told em that and I want just wondering.
I hhave low compression LS/VTEC right now because its stock, Im just looking to boost the vtec changeover and add a bit of hp! thanks
Old Feb 24, 2005 | 11:42 PM
hitvtecgetloud09's Avatar
Default Re: Quick Cam Questions.. (Sean R81)
if ur goin to boost later on get the gsr cams..also ur goin to need to adjust ur valves and i sugjest if u havnt done this b4 have some one do it for u.. u dont eana "freeze" your cams
Old Feb 25, 2005 | 12:03 AM
hi mom's Avatar
Default Re: Quick Cam Questions.. (hitvtecgetloud09)
Well I dont plan on boosting the car. I understand the ideal way is low comp, right now I think it sits 8.1:1, great for boost. Im just looking to get a larger sounding vtec changeover, and a couple extra HP. I got a good quote on cams installed, and my aem gears adjusted aswell.
Like I said above, would I need to do complete head set, valve springs, retainers etc if I did ITR cams?
Old Feb 25, 2005 | 12:19 AM
DarkSolPR's Avatar
You dont need valvesprings if you dont rev it above the stock rev limit(8200),but with that comp. you dont gonna see the true potential of those cams, put some B16(P30) pistons,ITR valve springs, and CTR(IRT99-00) cams then rev it to 9k then you shoul see their true power
Old Feb 25, 2005 | 07:04 AM
UncleD's Avatar
Default Re: Quick Cam Questions.. (DarkSolPR)
*Pet peeve of mine when people think a gsr camshaft is better than a b16 *
https://honda-tech.com/zerothread?id=1113834
Old Feb 25, 2005 | 08:50 AM
hi mom's Avatar
Default Re: Quick Cam Questions.. (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">*Pet peeve of mine when people think a gsr camshaft is better than a b16 *
https://honda-tech.com/zerothread?id=1113834</TD></TR></TABLE>
Understandable, I dont know much about it so I thought I would ask.
So I should get a more noticable changeover and some more power if I add some ITR cams with valve springs and maybe B16 pistons?. Why not GSR pistons?
Old Feb 25, 2005 | 11:32 AM
00Red_SiR's Avatar
All Motor Mentor
Stock GSR pistons are dished so they'll do nothing to help your low compression issues.
Old Feb 25, 2005 | 01:08 PM
hi mom's Avatar
Default Re: Quick Cam Questions.. (00Red_SiR)
Okay, so I found a deal on ITR valvetrain.
ITR cams, springs and retainers + valve adjustment and install.
Old Feb 25, 2005 | 01:28 PM
JoeB18R's Avatar
you want CTR pistons on an ITR crank. add in a 2 layer head gasket and you have enough compression to run pretty much any cam you want,
Old Feb 25, 2005 | 02:25 PM
hi mom's Avatar
Default Re: Quick Cam Questions.. (JoeB18R)
Okay, none of you guys are answering my questions, your just thorwing out oddballs.
Im talking about the head, no block work, I cant afford that yet.
Would upgrading to ITR cams, valve springs and retainers help with vtec changover, and what kind of hp numbers am I looking to gain?
Old Feb 25, 2005 | 03:16 PM
89civicsinKC's Avatar
Cams and valvetrain affect where you set the Vtec engagement point. Itr cams would make more power than you stock B16 cams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean R81 &raquo;</TD></TR><TR><TD CLASS="quote">larger sounding vtec changeover</TD></TR></TABLE>
What the hell does this mean anyway? If you wanna go faster just shift mad quick yo!
Old Feb 25, 2005 | 03:46 PM
hi mom's Avatar
Default Re: Quick Cam Questions.. (89civicsinKC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89civicsinKC &raquo;</TD></TR><TR><TD CLASS="quote">Cams and valvetrain affect where you set the Vtec engagement point. Itr cams would make more power than you stock B16 cams.
What the hell does this mean anyway? If you wanna go faster just shift mad quick yo!</TD></TR></TABLE>
haha sorry, the reason my car doesnt have such a loud vtec engagment is because the low comp. I was told the head would imporive that a little more, until I can afford to get pistons..
Old Feb 25, 2005 | 04:51 PM
tonezilla's Avatar
i'd hope i am not off topic but will upgrading the cams alter the air or fuel settings, on say a stock engine, cause it to run rich or lean ?
Old Feb 28, 2005 | 03:26 PM
Default Re: Quick Cam Questions.. (redxalien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redxalien &raquo;</TD></TR><TR><TD CLASS="quote">i'd hope i am not off topic but will upgrading the cams alter the air or fuel settings, on say a stock engine, cause it to run rich or lean ?</TD></TR></TABLE>
Of course it will. When you alter the amount of air the engine takes in via valve timing event and don't change the change the amount of fuel it gets you will also alter a/f ratios. Mind you that this is in closed loop where the engine is not going off of the 02 sensor
Old Feb 28, 2005 | 03:43 PM
00Red_SiR's Avatar
All Motor Mentor
Just changing cam gear settings on stock cams will throw off the air fuel ratios. Cam timing and profile have a huge impact on the way a cylinder fills.
domestic_rice
Aug 14, 2010 04:38 AM
Tong.Y
Apr 8, 2010 04:59 PM
tatted91rex
Apr 23, 2006 10:53 PM
esp4life
Mar 8, 2005 12:25 PM
pHizerDC4
May 23, 2003 01:10 PM
