Help me diagnosis my problems.. (valve & axle related)
Old Feb 24, 2005 | 07:38 PM
Jimmy's Avatar
Global Moderator
Default Help me diagnosis my problems.. (valve & axle related)
Engine: D16z6
Tranny: s20
Mods: i/h/e & acthdss clutch kit, fidanza 6.5lb flywheel.
Recently on idle i hear a clunking/loose sound, it doesn't happen at every stop,but it seems to happen when my idle drops a little bit.
I thought i had it narrowwed down to my axles because i noticed that there is a very minor tear in the CV boot.
I also wiggled the axles and they don't seem to be as tight as they should be, they shouldn't hardly move at all, correct?
If i put my foot on the break and try to stall the car out i also hear this sound louder.
<FONT COLOR="red">Issue #2</FONT>
Now that the weather is changed (being cold) About two months ago i ran 87 gas.. at around 4000 rpms in third gear mashing it.. I hear valve chatter. I switched to 93 octane and haven't had a problem with that since,but now it seams my valves or something is making a high pitched sound.. kinda like a squeeling.. it happens in when i'm just barely on the throttle... Do my valves need to be adjusted?
Thanks In advance.
Old Feb 25, 2005 | 02:09 AM
rocketfuelcerx's Avatar
Default Re: Help me diagnosis my problems.. (Jimmy)
possibly the axles(more likely this if you have negative camber) ...but consider this
I had the same clunking noise whenever I would go down a driveway or sometimes coming to a stop but not all the time and not on the freeway and it turned out to be a dead front strut.... ....oh yeah my strut didn't sound when compressed only depressed ie.slight uphill stops, going down driveways, launching ... Hope this helps...
Old Feb 25, 2005 | 06:26 AM
Jimmy's Avatar
Global Moderator
Default Re: Help me diagnosis my problems.. (rocketfuelcerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocketfuelcerx &raquo;</TD></TR><TR><TD CLASS="quote">possibly the axles(more likely this if you have negative camber) ...but consider this
Thanks man..
I do have negative camber and i'm riding on neuspeed fullbody coilovers and they're not that old, but ill take a look.
Old Feb 25, 2005 | 10:21 PM
Jimmy's Avatar
Global Moderator
ttt
saemoonyang
30
Jul 3, 2010 09:38 AM
jawsiiv
Nov 10, 2008 03:28 PM
Jimmy
24
Mar 4, 2005 11:12 AM
Hoosier Daddy
Feb 22, 2004 01:54 AM
