fuel leaking not gas tank though
Old Feb 24, 2005 | 06:19 PM
OPTION2ek V.2's Avatar
Default fuel leaking not gas tank though
i have a 1992 honda civic cx hatchback and i noticed when i do hard turns or go on hills i smell fuel when my window is down.i jacked up my car and looked underneath thank god it wasnt comming from the fuel tank.looks more like it dripping down from the filler neck area.wanted to see if it was something common or if you guys have this similar problem?just wanted to see what it could be.also is it hard to drop the gas tank?thanks in advance!
Old Feb 24, 2005 | 06:40 PM
sohcvtec1995's Avatar
Default Re: fuel leaking not gas tank though (TEE CAT)
gas tank is not that hard but its also not fun.
Old Feb 24, 2005 | 06:46 PM
T4eg's Avatar
Default Re: fuel leaking not gas tank though (sohcvtec1995)
the tank is easy as hell to drop. Just removed the backseat and pull off the cover plate. Then unconnect the plug and 2 lines. then remove the filler tubes and loose the nuts to drop the strap (try to do it with not much gas in tank AND use a jack or something to lower it down)
Chris
Old Feb 24, 2005 | 06:59 PM
b20vtechatch
Guest
Posts: n/a
Default Re: fuel leaking not gas tank though (BlueHatch00)
how hard is it to replace the fuel line that goes from the filter to the tank? and where can i get it bent already?
Old Feb 24, 2005 | 07:18 PM
Default Re: fuel leaking not gas tank though (b20vtechatch)
thanks for thread jacking
James Parkhill
Oct 24, 2016 06:15 PM
FO SHO
Apr 11, 2010 01:30 PM
blaze_125
Sep 5, 2007 06:47 AM
TealCivic93
Apr 8, 2006 09:31 AM
Hard2Find
Aug 16, 2004 08:47 PM
