changing to a thinner head gasket
Old Feb 24, 2005 | 05:53 PM
93FastLs's Avatar
Default changing to a thinner head gasket
it's 94 c1 if i change to the mugen head gasket, the thinner one do i still have to clay it for clearence ?
Old Feb 24, 2005 | 05:57 PM
onepoint6i's Avatar
Default Re: changing to a thinner head gasket (93FastLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote">it's 94 c1 if i change to the mugen head gasket, the thinner one do i still have to clay it for clearence ? </TD></TR></TABLE>
You should clay depending on what dome piston your going to run and the amount of lift on the cam your going to use...Yes it will make a difference when you run that head gasket..in other words if your mild on the domes I wouldnt worry about it..Unless you have really aggresive cams..
Old Feb 24, 2005 | 06:08 PM
93FastLs's Avatar
it's a fully stock gsr motor that im going to change the water pump belt tensioner and timing belt along with all the gaskets and seals on the top end . i figured i would just buy a good head gasket
Old Feb 24, 2005 | 06:11 PM
onepoint6i's Avatar
Default Re: (93FastLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93FastLs &raquo;</TD></TR><TR><TD CLASS="quote">it's a fully stock gsr motor that im going to change the water pump belt tensioner and timing belt along with all the gaskets and seals on the top end . i figured i would just buy a good head gasket </TD></TR></TABLE>
perfect...You dont have to worry about claying nothing...just add the head gasket and go..keep in mind that your cam timing is going to retard abit so your gonna need cam gears to get it back to stock..
WOODman
Jun 6, 2005 04:08 PM
93FastLs
Feb 2, 2005 10:24 AM
sonicmoremusic
Sep 28, 2004 11:32 PM
spaceman
23
Apr 29, 2004 10:25 PM
fknfast
Mar 1, 2004 07:23 PM
