HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT
Old Feb 24, 2005 | 05:45 PM
EGhatch22's Avatar
Default HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT
i finshed my h22 swap into a 92 dx hatch, im using a civic harness with a p28 chipped ecu. The check engine light comes on like 15 minutes into drive. I turn off my engine without disconnecting the battery and start it after i get out of work and the check engine light is off. Then it goes on 15min later. The code is 9 the CYL sensor. I check the wires to the distribitor everything right. Does anybody have any suggestion how to fix it?
Old Feb 24, 2005 | 06:02 PM
onepoint6i's Avatar
Default Re: HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT (EGhatch22)
DiD you have to wire the cyl sensor yourself or did you just plug and play?
Old Feb 24, 2005 | 09:19 PM
andeshii's Avatar
i had that prob with my gsr swap in a civic we finally tracked it down to an o2 sensor missing no biggy might be what your having have you pulled the code yet?
Old Feb 25, 2005 | 10:48 AM
EGhatch22's Avatar
Default Re: HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT (1.6i)
plug and play
Old Feb 25, 2005 | 10:49 AM
EGhatch22's Avatar
Default Re: HELP!!!! CHECK ENGINE PROBLEM CANT FIGURE OUT (andeshii)
the code is 9 the CYL sensor i have my o2 sensor hooked up
Old Feb 25, 2005 | 06:40 PM
PrettyLude's Avatar
code 9 is a sensor inside your distributor, maybe ur dizzy is about to crap out on you
jayrod7
Jan 21, 2010 01:45 PM
mtime
Dec 17, 2009 09:17 PM
greyejcoupe
Oct 3, 2009 10:48 AM
eatbieodie2
May 7, 2005 08:05 PM
