91 Accord with steering wheel shutter.
Old Feb 24, 2005 | 05:10 PM
ledebuhr1's Avatar
Default 91 Accord with steering wheel shutter.
I have an 91 Accord. At speeds above 55mph, the steering wheel shutters side to side about 3/4". The car drives fine but this is kind of a nusance. It is only noticalble at higher speeds. Could it be the rotors have some "wobble" in them?
thanks
Old Feb 24, 2005 | 06:53 PM
90accorddx's Avatar
Default Re: 91 Accord with steering wheel shutter. (ledebuhr1)
I could be broken belts in the tires or a unbalanced tire, maybe balljoints the only way it would be the rotors if it shudders when you hit the brakes check the tires first if any of the have a bubble then a belt in the tire is broken you might want check and see if you lug nuts are tight too
Old Feb 25, 2005 | 03:31 AM
ledebuhr1's Avatar
Default Re: 91 Accord with steering wheel shutter. (90accorddx)
Thanks,
The tires are in very good condidtion, and have lots of tread left. Whats odd is that it is really only noticable at higher speeds. If something was out of balance wouldnet it do it all the time? how can I check the ball-joints?
Old Feb 25, 2005 | 03:33 AM
The_Todd's Avatar
Farts in the shower
My guess would be rotors are warped or you need an alignment.
Old Feb 25, 2005 | 09:32 AM
ledebuhr1's Avatar
Thanks
anyone eles have any suggestions?
rocru
May 29, 2012 11:36 AM
anlee
Apr 26, 2012 12:14 AM
prelude_93vtec
May 16, 2007 02:40 PM
HONDA92HATCH
Nov 25, 2004 04:15 AM
