Electrical Question....
Old Jan 20, 2002 | 12:49 AM
escocrx's Avatar
Default Electrical Question....
I have this hummin noise comin from under the dash area. I cant find its origin, I think it also is part of a big problem of my power leak also which drains the battery overnight. I was wondering if anyone has had this lovely hummin noise. Its only when the car is completely off. It also goes away when i plug my alarm in, the instant i disconnect it, it will begin humming again. It also stops after turnin the key to the ON position. NO clue why.
PLEASE HELP.
I'm goin to have to do a complete break down to fix this.
1991 CRX Si
Old Jan 20, 2002 | 02:08 AM
AfEn808's Avatar
New User
Default Re: Electrical Question.... (escocrx)
my car also drains but not over night to find the problem is pretty hard what you would have to do is have a pretty good ammeter or amp meter and connect it to your negative battery cable and your - battery post then begin to pull fuses if you see the amps drop thats probably the circuit thats killing your battery it probably has a big short in it, then you would have to just go about and look through that whole circuit hope that helps if not I would just have a proffesional technician look at it.
Dontoh
Audio / Security / Video
Jul 6, 2010 03:32 PM
komat
Dec 11, 2009 01:52 PM
Goodaddy
14
Sep 14, 2009 07:52 AM
91akira
Oct 21, 2008 06:29 AM
Iron_Forrix
10
May 6, 2008 09:45 PM
