Battery drain problem Question
Yes, all memory settings will be lost any time the battery is disconnected.
You really need to find out what is causing the current draw and draining the battery.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">Yes, all memory settings will be lost any time the battery is disconnected.
You really need to find out what is causing the current draw and draining the battery.</TD></TR></TABLE>
This will work, but eventually the drain will kill it while it's running.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaHeddie »</TD></TR><TR><TD CLASS="quote">battery cut-off used to fix a phantom drain?
sorta like
turning up the radio to fix a flat tire
j/k
fix the wires, you will regret it if you dont</TD></TR></TABLE>
A little closer to using a band-aid to cover a shotgun wound.
sorta like
j/k
esoterEK..
16
Mar 11, 2004 08:02 AM
