Maximum safe boost on a stock D16Y8 tuned with Hondata
Old Feb 24, 2005 | 03:26 PM
_Cyclone_'s Avatar
Default Maximum safe boost on a stock D16Y8 tuned with Hondata
I know this is probably the most common question asked in this forum, but my search failed to reveal any concrete answers about my specific situation... plus I'm kind of a n00b when it comes to boost. I'm just looking for a roundabout figure to get an idea. I have a 97 D16Y8, bone stock, 100K. I'll be boosting on pump gas with a greddy 15g kit, 31" Coach intercooler, DSM 450's, Hondata s200b and controlled by an Apexi AVC-R. The Y8 that the kit came off of lasted approx. 5 years on 10psi. I'm going to be having it professionally tuned right after the installation. I'm just looking for a roundabout figure. Thanks Guys!
Old Feb 24, 2005 | 03:51 PM
miro_gt's Avatar
Default Re: Maximum safe boost on a stock D16Y8 tuned with Hondata (CycloneBlue_1.6EL)
9psi ... at 10 the risk is jumping significantly, at least that's my estimate of what everybody says running at 10 - mostly coolant problems, assosiated with the headgasket occur
Old Feb 24, 2005 | 03:55 PM
platinum00's Avatar
Default Re: Maximum safe boost on a stock D16Y8 tuned with Hondata (miro_gt)
many people have made alot of power with a stock motor.
dont worry about the psi figure. you want to look at the power figure. the motor blows because of to much power, not to much boost.
i would say your fine till around 200, then you going to need some forged pistons and stuff.
tunning is the key, get it done right, and you will have no problems.
platinum.
Old Feb 24, 2005 | 03:57 PM
oxSLEEPERxo's Avatar
Default Re: Maximum safe boost on a stock D16Y8 tuned with Hondata (platinum00)
its all on the tunning, but d16z6 and d16y8 stock internals can handle 220-230whp, it can handle more, if u have a good tuner
Old Feb 24, 2005 | 03:59 PM
93turbo16's Avatar
like stated above it is all about the power and the quality of the tune
Old Feb 24, 2005 | 04:15 PM
miro_gt's Avatar
Default Re: (93turbo16)
yeah, I should say it with HP instead of psi ... so my guess is that about 185WHP is a good number for a stock D-motor ... at 200WHP the risk to have problems is jumping a lot more
Old Feb 24, 2005 | 04:19 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: (miro_gt)
the 10-11psi limit on a stock D is only if you're running based off the stock map sensor which hits it's voltage ceiling at ~10.5psi.
consensus on hp ceiling on a stock D is approximately 230-250hp with a very good tune. The rods become the weak link at this point if the tune is good enough not to detonate and take out a piston.
Old Feb 24, 2005 | 04:50 PM
SOHC_MShue's Avatar
i would shoot for 200whp and keep it around there.
Old Feb 24, 2005 | 05:52 PM
_Cyclone_'s Avatar
Default Re: Maximum safe boost on a stock D16Y8 tuned with Hondata (SOHC_MShue)
Thanks for all the responses. I should have indicated in the initial post that my power goals were actually between 180-200whp. I'm not sure I'll even be able to squeze that much out of it, because I'll be using the stock exhaust piping with an apexi n1 axel-back for now. I'm not sure what to really expect... my only advantage is the s200b... now I have to find a local tuner shop that can tune Hondata. I'll probably have to drive to Toronto...
Do people ever make decent numbers on stock piping?
Old Feb 24, 2005 | 06:02 PM
Blaze45's Avatar
Brrraaaap!
DO NOT RUN A STOCK EXHAUST WHEN BOOSTING. Its like trying to drink a 64oz cup of pop with a gay coffee straw, you just dont do it. My friend did it for a while. He was running 6psi (whatever the stock internal WG setting was at) stock exh. for a while. Had 2.5in piping installed all the way back and boost went to 11psi. He turned it down tho. Get a good exh. setup, you wont regret it.
Blaze
Old Feb 25, 2005 | 05:33 AM
_Cyclone_'s Avatar
Default Re: Maximum safe boost on a stock D16Y8 tuned with Hondata (Blaze45)
For now, I just don't have a choice. Maybe things will change in the next month or so, I plan to install in april when it's warmer. I can get one of those cheap generic ebay 2.5" mandrel cat-backs for ~$140 plus 100 for shipping, then when ******* canada customs clears it, another $200 COD. I wish I lived in the US.
Tapen00n
Jul 2, 2025 01:08 PM
Masho
Honda Civic (2001 - 2005)
Dec 9, 2010 11:34 AM
FRKWOO
13
May 1, 2009 06:14 PM
sladed16y8
Jan 22, 2007 07:19 PM
Happyman
May 10, 2003 04:18 PM
