When go sleeve a block?!?
Old Feb 24, 2005 | 03:09 PM
seen4ever's Avatar
Default When to sleeve a block?!?
At what power level do most of you guys recommend moving to a sleeved block?
with my old setup, i was at 355whp @ 14psi on 93 and run a 11.75.
after upgrading my valvetrain this year(reving to 9500 instead of 8100), switching from a t3/t4e to a gt35e and with moving to 1000cc injectors, adding the fluidamper to save my oil pump & bearings. I started to realize that hey, my setup may not be strong enough to ensure survival of my block this season.
So is there a line? I'm sure alot will say tuning, which I think is 80% of the truth, but with my goal of hitting a 10.xx pass this year, and probably starting to run race gas and crank up the boost, i think i'll be around the 500whp mark.
Just wondering what others think.
current setup:
b18c1
81.5mm Endyn rollerwaves 9.2:1
eagle rods
stock head
t3/t4oe 60 trim, stage 5
Autolab manifold, 3in downpipe, dumptube
tial 35mm, .6 bar
RC 550
Hondata s200b (self tuned)
Greddy Type 24 IC
new setup
block ?!?!
.5mm overbored supertech valves with supertech springs & retainers
Precision GT35e
tial 38mm, .9 bar spring
Precision 1000cc
Hondata 200b
Same autolab turbo manifold/piping setup
same ICer
GE scattersheild
Buck02 Limit Straps
6-pt cage, 3in harnesses
basicly, i have everything, but my block is still the old setup, so timing is running out to decide...
Old Feb 24, 2005 | 03:24 PM
dunkd's Avatar
theres no real line. I know DRT's drag car was making big power (600whp) on stock sleeves...
Old Feb 24, 2005 | 03:25 PM
boost fed ls's Avatar
Default Re: When to sleeve a block?!? (seen4ever)
This question is really up for debate, I would sleeve for a 500+whp goal. Some people say when you are 400whp+ you should sleeve. I am sure there are people on here with 450-500hp range and still on stock sleeves. My goal when I get my motor done in a month is 400+ and I am omn stock sleeves with a block guard. Another big factor is the tuning. But once again for you high hp goal def. sleeve the block
Old Feb 24, 2005 | 03:45 PM
seen4ever's Avatar
Default Re: When to sleeve a block?!? (boost fed ls)
Another reason i pulled the motor when i pulled the head off was to inspect the sleeves and everything looks good to go, who knows.
oh yeah, the motor currently has around 7k miles on the setup with everything replaced at rebuild.
Old Feb 24, 2005 | 03:59 PM
platinum00's Avatar
how much power are you looking to make.
400+ on stockers is not uncommon now, if your tunned right.
really peace of mind i would say. im only shooting for 350-400 and i sleeved mine
prolly not needed, but i feel better about the build
platinum.
Old Feb 24, 2005 | 04:15 PM
seen4ever's Avatar
Default Re: When to sleeve a block?!? (platinum00)
goal is to be around 400whp on 93 and 500whp with c16. but really just to run a 10.xx pass. yet i've added a 6pt rollcage and two sparco torino's so that won't be easy on the weight of the car, as that mild steel cage really added up.
Old Feb 25, 2005 | 12:34 PM
seen4ever's Avatar
bump for more opinions.
Old Feb 25, 2005 | 02:18 PM
NJIN BUILDR's Avatar
It matters how much you want to gamble.Your in the range that a little miss on the tune and its bye bye cylinder.I'd hate to go up in smoke after winning the semi.
Glenn
Old Feb 25, 2005 | 02:52 PM
X-Mazda 3 Racer's Avatar
Default Re: When to sleeve a block?!? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">It matters how much you want to gamble.Your in the range that a little miss on the tune and its bye bye cylinder.I'd hate to go up in smoke after winning the semi.
Glenn</TD></TR></TABLE>
Agreed 100%
Old Feb 25, 2005 | 05:52 PM
Race Egr's Avatar
Default Re: When to sleeve a block?!? (GoldenEagleMfg.com)
seen sleeve that beast and feed it race gas and go get yourself a 10 sec pass
Old Feb 25, 2005 | 07:08 PM
PrettyLude's Avatar
sleeving=extra insurance
Old Feb 25, 2005 | 07:57 PM
rmcdaniels's Avatar
I didn't sleeve mine until my stock sleeves were so out of round that they were visibly oval. Blow up your stock sleeves, then go get some stronger ones.
Old Feb 25, 2005 | 07:58 PM
seen4ever's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed 100% </TD></TR></TABLE>
oh yeah, i sent you an email 2-3 days ago, asking about pricing and such around this very question
in a way, i just want to gamble just to make 500whp on stock sleeves, and then again, i'd have to pop in the middle of a race and wait on AAA.
Old Feb 26, 2005 | 11:52 AM
Danethomp's Avatar
don't be a p*ssy. sleeve it and sell jason ur old block.
Old Mar 1, 2005 | 09:10 AM
88crxvtec's Avatar
Default Re: (90g2ls)
or buy my Darton Sleeved block.
84.5mm b16w/crank and acl bearings
Old Mar 1, 2005 | 09:26 AM
spectacle's Avatar
Default Re: (88crxvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crxvtec &raquo;</TD></TR><TR><TD CLASS="quote">or buy my Darton Sleeved block.
84.5mm b16w/crank and acl bearings </TD></TR></TABLE>
PM me price
Old Mar 1, 2005 | 09:40 AM
seen4ever's Avatar
its on my radar, but then again, i lose displacement, plus the additional machine work needed to get stuff in spec. but i'm thinkin about it.
Old Mar 1, 2005 | 12:18 PM
turbo-d's Avatar
hey man im from lousiville ky too. send me a message.
In3g_Eg6
Feb 23, 2011 03:11 PM
J1A1H
Sep 30, 2006 03:43 AM
WH0R3nEF9
Nov 3, 2005 05:09 PM
yellowhonda88
Feb 6, 2004 12:33 PM
gsrcivict
Apr 16, 2003 07:26 AM
