oil leaking from timing belt. help?
Old Feb 24, 2005 | 02:42 PM
screamo's Avatar
Default oil leaking from timing belt. help?
so i bought this '99 coupe EX not too long ago. it has a bone stock SOHC vtec motor and it runs fine. but in the past few weeks ive noticed it has been leaking some oil in my parking spot. and at first i thought it was from my drain plug, but i tightened it and its still leaking oil. so i checked the thread on the oil pan, because maybe the threads are weak, but thats not the problem either. eventually i find out the oil is leaking from the timing belt area, and i dont know why...does anyone know how i should fix this? should i replace the belts, or something? im not losing too much oil per day, but id rather fix it before it becomes a real hassle. its my first car, so im trying to learn what i can about it.
Old Feb 24, 2005 | 03:27 PM
sohc93vtech's Avatar
Default Re: oil leaking from timing belt. help? (screamo)
i had the same problem on mine and it was the cam seal located behind the sprocket.
Old Feb 24, 2005 | 03:56 PM
Echo7847's Avatar
Default Re: oil leaking from timing belt. help? (sohc93vtech)
Cam or Crank seal
While you're down there might as well do the t-belt/water pump.
Old Feb 24, 2005 | 04:03 PM
screamo's Avatar
most def. will check those out. thanks guys.
Old Feb 24, 2005 | 04:20 PM
Lmgrcivic's Avatar
Default Re: (screamo)
had to be the crank seal SOHC dont have a cam seal
Old Feb 24, 2005 | 08:18 PM
Echo7847's Avatar
Default Re: (Lmgrcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">had to be the crank seal SOHC dont have a cam seal </TD></TR></TABLE>
Incorrect:
#21 is the cam seal
Old Feb 24, 2005 | 08:21 PM
ian.'s Avatar
Old Feb 24, 2005 | 09:32 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (IC33)
yeah, cause there's no oil supply to the head and cam huh
Old Feb 24, 2005 | 09:33 PM
Mike K's Avatar
douche bag lol
Old Feb 25, 2005 | 03:15 AM
Lmgrcivic's Avatar
Default Re: (Mike K)
sorry I meant the type of cam seal that the DOHC's have hey I can admit when Im wrong I stand corrected
Old Feb 28, 2005 | 10:17 AM
screamo
goodluck with your prob
Old Feb 28, 2005 | 10:43 AM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by screamo &raquo;</TD></TR><TR><TD CLASS="quote">so i bought this '99 coupe EX not too long ago. it has a bone stock SOHC vtec motor and it runs fine. but in the past few weeks ive noticed it has been leaking some oil in my parking spot. and at first i thought it was from my drain plug, but i tightened it and its still leaking oil. so i checked the thread on the oil pan, because maybe the threads are weak, but thats not the problem either. eventually i find out the oil is leaking from the timing belt area, and i dont know why...does anyone know how i should fix this? should i replace the belts, or something? im not losing too much oil per day, but id rather fix it before it becomes a real hassle. its my first car, so im trying to learn what i can about it. </TD></TR></TABLE>
did u try changing the washer on the drain plug? it's a special crush washer that's supposed to be replaced with each oil change.
Josueneta
May 7, 2010 01:43 PM
black0hatch
Feb 13, 2010 06:59 AM
Stevegunit16
Nov 5, 2006 02:45 AM
ID_ten_T
Feb 4, 2004 08:27 PM
mike2016
Aug 23, 2002 05:13 AM
