ZC guru's need help...
Old Feb 24, 2005 | 01:55 PM
sleepin91teg's Avatar
Default ZC guru's need help...
Well i posted on TheZCR.com but it moves slower than my grandma drives, so im bringing my question here...i need head studs for my dohc zc...heres the deal...
I did a well search, and found this...but still not totaly sure about what to get, do i call ARP and tell them those dimensions (gave 2 difference measurements for the thread 1.35" and 1.25") or do i just order for a b16? heard with bseries vtec studs the middle stud hits th intake came...i dont wanna have to modify this stuff, i want the actuall parts, to bolt right in...ANYONE?!?!
So here it is, I went and mesured my bolts, head, block, threads.
11mm
1.5 pitch
1.35 inch long thread
6.5 Inch long
0.08 Washer thickness
0.8 washer Diamiter
Head depth 2.775
Bolt depth 3.59375
Keep in mind my block is milled 0.020, so this should = out to the length of the bolts minus the bolt head.
Now the VW kit doesent work because the bolts arent long enough However, B16A studs are 11mm 1.5 pitch threads 1.25 long thead length and are 7 inches long as well as being all the same length! So there you have it.
--SethZC
Just off the phone with ARP directly...According to those numbers up there^^^ the part numbers they gave me are this...
Studs: ATP6.500-1UB
Nuts: 300-8333
Washers: 200-8530
When i talked to LIAM he gave me these part numbers (for a dodge neon)
Studs: ATP6.760-1LB
Nuts: APN12-1
Washers: APW 1316N
Can some one please verify this...im in major need, and not boosting till this is done!!!
Old Feb 24, 2005 | 04:47 PM
Default Re: ZC guru's need help... (sleepin91teg)
Geez sorry its sooo long, just got detailed info...bump for help!
Old Feb 24, 2005 | 04:52 PM
Garrett's Avatar
I bought B16 stud and grind the one in the center to clear the cam
Old Feb 24, 2005 | 04:53 PM
mar778c's Avatar
Community Builder
Community Influencer
Just checked the ZCR.com forum
Here's the link
http://www.scchosting.com/chri...p.htm
Studs: ATP6.760-1LB
Washers: APW1316N
Nuts: APN12-1
You will need 10 of each
Try
Race Engineering
http://www.raceeng.com/
Old Feb 24, 2005 | 05:25 PM
mr_valentino20032000's Avatar
Default Re: ZC guru's need help... (mar778c)
yeah i remember seeing something about that on http://www.homemadeturbo.com but he used VW head studs.
If i remember later i'll do a search on there..but if i forget then just look for one of the owner of the sites builds
Old Feb 25, 2005 | 04:42 PM
Still looking for <U>THE</U> answer...
Old Feb 25, 2005 | 04:46 PM
crxgator's Avatar
um...order the headstuds for a dohc zc...they make it for em now...also the VW 16v would work as well...
Old Feb 25, 2005 | 04:52 PM
Default Re: ZC guru's need help... (crxgator)
I called ARP and AEBS directly, and no one heard of the dohc zc, or the ZC for that matter...sux
Old Feb 25, 2005 | 04:55 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin91teg &raquo;</TD></TR><TR><TD CLASS="quote">I called ARP and AEBS directly, and no one heard of the dohc zc, or the ZC for that matter...sux</TD></TR></TABLE>
then you talked to a bunch of idiots...
Old Feb 25, 2005 | 04:57 PM
Talked to 3 people at each place...called back and forth pretending to be someone new...get me a part # if u know its out...
Old Feb 25, 2005 | 05:03 PM
crxgator's Avatar
one sec, i know i saw it before cause i was looking for it for my old zc....
204-4204
msmithgsr2131
14
Feb 22, 2012 04:52 AM
4g4dcruisin
Feb 1, 2010 03:10 PM
kornerk12
Jun 28, 2009 06:55 AM
ELSpool
Jul 28, 2003 11:21 AM
