Sleeved blocks/forged pistons -- How many of you use the factory oil squirters?
Old Feb 24, 2005 | 01:36 PM
92TypeR's Avatar
FSAE
Default Sleeved blocks/forged pistons -- How many of you use the factory oil squirters?
I am having a B18C machined soon for this season. This will be my first sleeved block, along with my first time using forged pistons. I hear you need to machine the oil squirters to fit after sleeving. Should I follow through and machine them? Or are they necessary if I'm using forged pistons? I am thinking they will help keep pistons temperatures down during prolonged high-RPM useage, so my gut instinct is to keep them.
Discuss...
TIA for your feedback.
Old Feb 24, 2005 | 04:53 PM
Dr Pooface's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (92TypeR)
I've heard that eliminating the squirters helps to boost oil pressure, and that forged pistons don't require the oil for cooling. Myself, I'd keep them just to be safe.
Old Feb 24, 2005 | 05:07 PM
92TypeR's Avatar
FSAE
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">I've heard that eliminating the squirters helps to boost oil pressure, and that forged pistons don't require the oil for cooling. Myself, I'd keep them just to be safe.</TD></TR></TABLE>
See, thats what I've heard also, but for some reason my gut instinct tells me otherwise...
Old Feb 24, 2005 | 05:20 PM
chad's Avatar
Moderator
why would you elminate an oiling source??? even with forged stuff i'd always run oil squirters..
Old Feb 24, 2005 | 05:51 PM
Track rat's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (chad)
Not only do they help cool the piston, they keep the oil ring saturated too.
Old Feb 24, 2005 | 05:52 PM
92TypeR's Avatar
FSAE
Thanks for the reply Chad. EDIT: and Track Rat
I was going to try and use them.
Does anyone know the process of making the squirters fit an 85mm sleeve?
Old Feb 25, 2005 | 01:45 PM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
Does anyone know the process of making the squirters fit an 85mm sleeve?</TD></TR></TABLE>
Gently bend them so they fit without hitting anything.
Old Feb 25, 2005 | 07:46 PM
CHEETAH's Avatar
if using high mileage break in rings then yes continue to use teh squirters, if quick break-in race rings then no, buy the squirt plug blockoffs from endyn and block them off as they distribute too much oil under piston.
Greg
Old Feb 25, 2005 | 08:28 PM
rjay8604's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (CHEETAH)
I'm going to use them on my 85mm block. There aren't any clearance issues with my pistons, maybe with some strutted pistons, but mine are fine. I figure the oil squirters won't hurt and i'm using the higher flowing obd-2 oil pump so i should be fine.
Old Feb 25, 2005 | 09:53 PM
92TypeR's Avatar
FSAE
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (rjay8604)
Thanks for all the responses.
I am going to be using the oil squirters for sure now.
Old Feb 25, 2005 | 10:22 PM
earl's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">Not only do they help cool the piston, they keep the oil ring saturated too.</TD></TR></TABLE>They squirt on the underside of the piston, no where near the oil rings.
Old Feb 25, 2005 | 11:13 PM
Mike K's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (earl)
any of you guys running squirters in a sleeved (84mm or 85mm) GSR block with an LS crank?
Old Feb 26, 2005 | 03:57 AM
Bradstard's Avatar
Default Re: Sleeved blocks/forged pistons -- How many of you use the factory oil squirters? (Mike K)
I am running an 85mm bore and 89mm stroke B18C5 and I do not have my oil squirters. RLZ built the motor and they recommended taking them out for higher oil pressure and since this is not my daily drivers.
Old Feb 26, 2005 | 11:18 AM
Track rat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">They squirt on the underside of the piston, no where near the oil rings. </TD></TR></TABLE>
So, when that squirt of oil hits the underside of the piston, none of that oil hits the cylinder walls huh?
shandonwall
13
Apr 27, 2009 09:13 PM
FuNkDrSpOt
Jul 29, 2006 12:21 PM
JLHDOHC
Apr 24, 2006 06:17 PM
EITCP
Nov 1, 2005 09:48 AM
sweet
Apr 24, 2003 10:29 AM
